coil overs for a third gen
Old Mar 8, 2005 | 07:53 AM
95turbo gxe's Avatar
Ok while putting coil overs on my friends spec V I had a extra stut tower laying around the shop from a third gen. I tryed it and the coil over went right on. I had to remove the cap at the top of strut and they slid on. Would this work? Im just worried about the the springs being strong enough for the weight of the 3rd gen.Other than that it will go right on. How about some coil overs for the 4th gen? I know for a fact that the spec will go on just not sure about the weigh on the springs. let me know.
Old Mar 8, 2005 | 07:59 AM
mtcookson's Avatar
most likely the travel of the spec v's strut would be a bit different than the maxima's.
on the other side... if by chance we got lucky (which we probably won't ) the springs can easily be changed for a spring rate that better suits the maxima most likely.
kcidmil's Avatar
Hmm interesting.... Hard to tell, but I'd lean toward no. Seeing as how the Spec V is lighter than our Max's... The V6 of ours just might over do it. But that is my opinion... and I don't have an engineering degree like Matt.
But that is something to look into, comparing the weight of the Spec V vs. our Max. Plus the length of the strut assembly to a stock one.
Old Mar 8, 2005 | 08:05 AM
kcidmil's Avatar
A good potential for a coil overs.
Of course it wouldn't do us any good to change the springs if the strut bottoms out.
Only really one sure way to find out... slap the sucker on and see how it does.
Old Mar 8, 2005 | 08:14 AM
Scope's Avatar
Im izz sexay
Agreed x1000
BTW spec-v weighs around 2700 lbs. Maxima weighs roughly 3200 lbs. 500 lbs difference.
Old Mar 8, 2005 | 08:24 AM
kcidmil's Avatar
Originally Posted by VG Ill ridah
Agreed x1000
Hmm in that case... Is there a way to possibly replace the struts with Koni inserts? That would help out a lot. But if the original strut rides fine... there's no point. Just trying to see all possible views.
Old Mar 8, 2005 | 08:25 AM
yeah I was thinking of ordering some. But just dont wont to get stuck with them if it dont turn out good. Worried about it being realy bouncy due to compressing the spring. Keep letting me know. Anyone chime in with their 2 Cents.
Old Mar 8, 2005 | 08:36 AM
kcidmil's Avatar
Get some comparison pics. That'll help out a lot. Then we can visually see difference between them. See how far the spring sits, how far it could be dropped. The size (length and width) of the struts themselves.
Understand on now wanting to buy a whole set... see if your buddy will let you try them out on yours really quick. Saves wasting money if it doesn't work... and confirms without spending the cash.
Old Mar 8, 2005 | 08:45 AM
yeah well they are on his car now and I dont know if he will be willing to let me take them back off now that he got his car 4way alignment done today. Dam I should have taken pics of it and tryed it on the car. But now we will just have to figuer it out.
Old Mar 8, 2005 | 08:54 AM
kcidmil's Avatar
Take some quick measurments still on his car. Make sure to jack it all the way up to stretch out the strut. Plus you might be able to slip one of our struts next to it... to give some comparison. I'm sure he wouldn't mind that too much.
Old Mar 8, 2005 | 08:56 AM
Harvs94max's Avatar
well the spring rate wouldnt be a big deal because you can always order different rates the only problem would be how it sits on the strut and how tall the spring is if its a 6in spring prolly wouldnt leave much strut travel even on a high setting
93turbo how even did it sit on the strut and did you try it witha strut mount on top how did that fit
ive always thought it would be nice to find a car with a similar suspension and we could order some ground controls
Old Mar 8, 2005 | 09:06 AM
internetautomar's Avatar
mod or sell?
if I had the money, i'd have already found the solution
well I put the coil over on and it seemed that it would be able to travel some im not sure on how much it would have to travel. But it would have about 3to 5 inches of travel. If I can stick the strut up side his car and take some pics might be a few day before I can do this though.
Old Mar 8, 2005 | 09:07 AM
kcidmil's Avatar
Hmmm, this is getting closer and closer to someone taking the gamble on it. I would do it if I knew someone who had a Spec V that would buy them if it fell through.
I need a new suspension anyway, and possible coil over sounds much funner than the Koni replacement about now. But I don't have that much extra to blow if it does fall through.
I wonder if we could talk to the company. They might be willing to try it out... they wouldn't have any competition... But it's also getting them to take the gamble of the sales.
Man, when I first saw the thread, I thought it was another ..."where can I find coilovers for my Max?"... no offense 93turbo gxe, I never looked at who wrote it at first.
I guess this will have us talking for the next couple of days.
Old Mar 8, 2005 | 09:08 AM
it seem to slide on nicley. I removed the cap on the end of the strut and it went right over the strut and sit down nicely. the top cup would go right on too.
Old Mar 8, 2005 | 09:10 AM
mod or sell?
these are sleeve overs, not "real" Coil overs.
you'd still be using the original struts / housing.
and what about the rear?
yeah no newbie thread from me
Im hope I have found something for all of us here. I know that they will go right on but the ride is what im wondering about.well I ll be back when I got some more info.
Old Mar 8, 2005 | 09:19 AM
Harvs94max's Avatar
big deal if they are sleeves better than just springs
you could get your own spring rates and adjusted height to how you want very important for any kind of racing many of the civic and miatas that i know through autocross all run ground control sleeves with either illuminas or konis
for the rears they should be same as fronts
Old Mar 8, 2005 | 09:26 AM
Jeff92se's Avatar
I'm needing a caw
Maxima has a very short strut travel length. So good luck not killing these Sentra units
Old Mar 8, 2005 | 09:32 AM
mod or sell?
I don't have the specs on the sentra struts yet
Old Mar 8, 2005 | 09:37 AM
Scope's Avatar
Im izz sexay
I don't see anything wrong in gagging your friend and hog tying him in a closet to give this a go. j/p.
Old Mar 8, 2005 | 09:39 AM
Harvs94max's Avatar
you gotta kill this eh jeff
i still think it will work im not saying the sentra ones will work but if we could find a sleeve spring combo with a similar height to a stock spring but with a larger spring rate and then you could adjust it to a height you want i dont see how it wouldnt work as long as you didnt go super low im interested more for a suspension tuning tool rather than to see how low i can put the car
Old Mar 8, 2005 | 10:55 AM
Matt93SE's Avatar
STFU n00b!
slipping coilover sleeves onto your struts is the easy part.
the hard part is the extremely short suspension travel you have on the front when you do that. You can only lower the car about an inch or so before you run out of strut travel.
If you've ever looked at a 3rd gen with Sprint springs while it's sitting on the ground, you'll see there is less than an inch of shock travel before you bottom out... and cutting the bumpstops to fix that is a BAD idea.
Find a shock body that's shorter than the 3rd gen MAxima that has enough damping and doesn't require extensive mods to fit, and I'll give you the sleeve-over design I have...
Old Mar 8, 2005 | 11:33 AM
Harvs94max's Avatar
so what ur telling me is anything lower than an inch is bad so my intrax springs are bad
then what about a taller strut mount so the strut shaft sits higher im sure one could be fabed up poeple have done crazier things
im not arguing just trying to come up with ideas
kyle
Old Mar 8, 2005 | 12:08 PM
well good news I talked to the spec-v and we are going to give it a try tonight so by tommorow ill have some answers for you and some pics. Hope it goes well we shall see.
Old Mar 8, 2005 | 12:15 PM
-shock211-'s Avatar
i've been schooled by matt on this subject recently. take whatever he says as sad but true.
Old Mar 8, 2005 | 12:46 PM
mod or sell?
some people don't like accepting answers from people who have tried before.
Old Mar 8, 2005 | 12:49 PM
Harvs94max's Avatar
93turbo take pics and take pics of the strut mount im going to try and get a hold of a one and see what i can come up with
Old Mar 8, 2005 | 12:52 PM
-shock211-'s Avatar
yeah, what would the guy who's actually tried it know?...
Old Mar 8, 2005 | 01:32 PM
Harvs94max's Avatar
but i want em
i understand what matt is saying but im going to try a few things dosnt hurt to try ill proly learn some things in the process
Old Mar 8, 2005 | 02:08 PM
mod or sell?
just because it "fits" doesn't make it right
Old Mar 8, 2005 | 02:09 PM
Jeff92se's Avatar
I'm needing a caw
Old Mar 8, 2005 | 02:31 PM
Matt93SE's Avatar
STFU n00b!
Bwwhahahah
Old Mar 8, 2005 | 06:09 PM
mtcookson's Avatar
he tried them out and at the lowest setting of the coil overs it was a bit taller than the 2 inch drop he has if i understood him correctly. basically, with some shorter springs it would look correct... not sure on the travel of the strut though. i don't know enough about suspension.
the pictures are a bit small but you can get a general idea:
Old Mar 8, 2005 | 06:11 PM
mtcookson's Avatar
Old Mar 8, 2005 | 07:22 PM
kcidmil's Avatar
Tell that to the designers of the SSR and the PT Cruiser. Ugliest things I ever saw.
If I've learned one thing from the years of stereo work... ANYTHING IS POSSIBLE.
Pay no mind to them... they're just jealous because they never thought to try it before. And one thing I have noticed, is we tend to shy away from new things. (i.e. the MAXIMA grill)
And if it doesn't work out that well... we'll owe Matt an apology... I can admit when I was wrong. But I'd rather find out I was wrong than sit here wondering if it would have worked.
Old Mar 8, 2005 | 08:37 PM
ok well Mark posted the pics for me. Ok they went on with no problem. Ok they would only lower the car like a 1inch . the springs were too tall. But they give a dam good ride. Nice and firm not bouncy. Almost like a new car. But just got to find some shorter springs.
Ok Why do you have to hate on me trying something. ANd dont start biching and get a good thread locked
Old Mar 8, 2005 | 10:49 PM
Wiking's Avatar
True. Picture bits are too small and u need to be General Springs to jump into any idee...
Needs new, bIGGER.
Old Mar 8, 2005 | 11:22 PM
kcidmil's Avatar
Ok... it's getting closer. So it was all smooth huh? Didn't feel like the strut bottomed out all?
And all it needs is some shorter springs... well if push came to a VERY BIG shove... you could cut them... I'd rather find the correct springs myself.
Old Mar 9, 2005 | 05:53 AM
tripleGmax's Avatar
well cutting springs is bad, but this is really interesting.
