STS Problems
Old Mar 10, 2005 | 06:44 AM
MONSTERMAX's Avatar
STS Problems
What performance problems can a STS cause in the 3rd gen?
Old Mar 10, 2005 | 06:57 AM
MrGone's Avatar
none
Old Mar 10, 2005 | 07:04 AM
MONSTERMAX's Avatar
This is my problem. When i first start my car and everything is cold, switching gears is smooth and pedal response is great. As the car warms up, it takes a little muscle to switch gears and the pedal response and the cars acceleration is a little sluggish. Some one on this forum had mentioned something about my STS, but didnt get into detail. I just need some insight on what might cause my car to do this.
Old Mar 10, 2005 | 07:12 AM
MrGone's Avatar
STS shouldn't effect pedal response and acceleration.
FWIW my transmission is the same way, smooth shifting when its cold and gets alittle more 'hit and miss' when its up to operating temp.
Old Mar 10, 2005 | 07:19 AM
MONSTERMAX's Avatar
Thanks for the info. I was planning a fidanza flywheel upgrade. Hopefully, it would make things a little better as far as exceleration.
Old Mar 10, 2005 | 07:53 AM
Wiking's Avatar
STS?? CBS?? CIA?? AIC?? ECU=european communist union...
Old Mar 10, 2005 | 08:31 AM
Wiking's Avatar
Hey c'mon! Is your invented acronym STS = Superintelligent Transposition Semiparasiteswitch???
...OR SMTG better?
Old Mar 10, 2005 | 08:42 AM
MrGone's Avatar
wtf?
STS = Short Throw Shifter
Old Mar 10, 2005 | 10:06 AM
Wiking's Avatar
Originally Posted by MrGone
wtf?
Short Thank Soon - For THE Translation =FTT...
Old Mar 10, 2005 | 11:49 AM
subs1000w's Avatar
i think as the pivot ball warms up it expands and makes it harder to move
ive tryed spacing out the shifter housing with washers and greasing it up but it still isnt nearly as nice as the stocker
depending on how bad mine gets when the weather gets hoter ill proboly go back to a stock shifter thats been shortened to my STS length
Old Mar 10, 2005 | 12:01 PM
Cliff Clavin's Avatar
Way out West
If your acceleration is sluggish, it would have nothing to do with the shifter. I would look into your knock sensor and harness.
As for the shifter, I think subs is probably right, the heat expands the plastic pivot ball. Mine has the stock shifter and it shifts smoother when it's warm. In the morning, before the fluid gets warmed up, it is kind of stiff.
Old Mar 10, 2005 | 12:38 PM
MONSTERMAX's Avatar
Where can i get a harness and a knock sensor from?
Old Mar 10, 2005 | 12:51 PM
avmaldo's Avatar
internetautomart.com
Old Mar 10, 2005 | 02:08 PM
twinkle's Avatar
yea, you could try changing to a different, or a synthetic fluid when you put in the flywheel.
Old Mar 10, 2005 | 05:51 PM
ChrisCheezer's Avatar
after i put redline mt90 in my tranny it felt soooo smooth.. but i still not sts for me.
Old Mar 2, 2006 | 04:51 AM
jkmay01's Avatar
Lil 8
i have the same problem with my pacesetter STS, at first smooth shifting, but as the cat heats up the shifting becomes stiffer not as smooth, have heard the same thing about the pivot ball expanding, can you give some pics on the where you are placing the washers? thanks
Old Aug 28, 2006 | 05:43 PM
jkmay01's Avatar
Lil 8
has anyone with thier sts broken the small rubber band that sits in front of the shifter rod? has anyone replace the rubber band? or has anyone had to replace the whole assembly? I dont want to weld a metal bar there? let me know?
Old Aug 28, 2006 | 07:02 PM
Michael's Avatar
Back in a 3rd Gen.
yeah its a pretty common problem for that part to break. Its not very expensive from a discount dealer. I dont have FAST on this computer or I would give you a part number and price from a discount dealer but I think its around $35 or so.
Old Aug 28, 2006 | 07:47 PM
Michael's Avatar
Back in a 3rd Gen.
OK here you go.
Old Aug 28, 2006 | 08:12 PM
Hectic's Avatar
what do space shuttle missions have to do with maximas?
Old Aug 28, 2006 | 10:53 PM
Jon94SE's Avatar
I have the same deal with my STS when its warm. Usually going into first gets a little notchy and getting into third (quickly) can be a little tricky.
Old Aug 29, 2006 | 05:01 AM
jkmay01's Avatar
Lil 8
Originally Posted by Michael
man... thanks for the info greatly appreciated !!!!
ordered it from courtsey for like $35 will take like 3 to 4 days to get it!! Thanks for the part number though!!!
Old Aug 29, 2006 | 05:29 AM
89blackse's Avatar
"and falling like a rock"
YESSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS!!!!!!!!!!!! !!!!!!!!!!!!!!!!
THANK YOUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
to hell with this:
I've asked this like 5 times on this forum before, but whatever. Thanks again.
Old Aug 29, 2006 | 05:44 AM
jkmay01's Avatar
Lil 8
to hell with this:
thanks for the pick!! the metal bar that you welded, is the part rubber on the OEM assembly?
Old Aug 29, 2006 | 06:09 AM
89blackse's Avatar
yeah, it was. My rubber part had broken on both the left and right side causing my shifter linkage to sink down and begin rubbing on the cat heat shield. Click the link in my sig --> page 2, to look at more pics
DO NOT DO THIS MOD. If your motor/tranny mounts are worn it will more or less turn your shifter linkage into a transmission MOUNT, which it was not designed to do.
If I could do it all over again, I would have just bought this bracket and go out to eat at Outback+tank of gas instead of doing this mod and a STS.
Old Aug 29, 2006 | 06:31 AM
jkmay01's Avatar
Lil 8
yea i see what you are saying it will cause more issues with the weld. More less to replace the rubber bridge i'll have to totally remove the shifter assembly? or can i loosen a bolt here and remove the bridge? trying not to get too dirty!!
Old Aug 29, 2006 | 06:42 AM
89blackse's Avatar
I feel your pain. You may be able to loosen the bolt that holds up the shifter linkage to the support bracket with out getting under the car...but that is only true if you have already loosened the bolt before lol. The rubber bridge thing is riveted into the whole bracket assembly so you can't just replace the rubber part either.
It's a pain in the azz and you will break all the bolts holding up the cat but jack up the car and get dirty.
Remove the cat's lower brush shield, remove the cat, remove the heat shield, remove bolt holding the shifter linkage up (gonna be kinda hard) then remove the 4 bolts holding the bracket in place (they were kinda odd looking but you can figure it out) replace with the new bracket and reverse the steps.
Oh and if you do install a STS you will have to hammer a dent into the heat shield to clear the bottom of the STS unless you leave it at the stock height.
Good luck.
Old Aug 29, 2006 | 12:23 PM
blackandwhite's Avatar
To them I'm like an idol
After reading a thread about it on here, I avoided the whole pivot ball heating thing by leaving the nuts a little loose. If you tighten them all the way, it will SEEM fine during installation, but will give you hell when it gets hot. just leav a little play in it by not tightening it up all the way. Then, use loctite (blue) on it so the nuts don't back off from vibration.
Mine as been on for about a year. I had to go back 2 weeks after the install to add the loctite, but it's been all good since.
http://forums.maxima.org/showthread.php?t=439773
Old Aug 29, 2006 | 12:53 PM
89blackse's Avatar
take this guys suggestion to heart, when those nuts do fall off, you will most likely not be able to shift anymore.
I had plenty of time to think about this as I drove home one night in 1st gear, blinkers in full blink, for 5 miles..........
Old Aug 29, 2006 | 06:34 PM
jkmay01's Avatar
Lil 8
Good luck.
yea i do have a sts already in the car now. and i pretty much left it at stock height so i dont get the shifter scraping the top of the cat's heat shield!! lol
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
