Ok......so lemme get this straight......
Old Mar 10, 2005 | 04:43 PM
5 ltr. beater's Avatar
Based on the dyno numbers posted by Red92maxSE, and by what the guy that did his dyno said, can i get an adjustable fuel pressure regulator for my car, and have my car dyno tuned with a wide band 02 sensor and lean it out a little bit to gain about 5-10 more at the wheels?
Old Mar 10, 2005 | 07:13 PM
MrGone's Avatar
Chris = Red92MaxSE
Profile Link
http://forums.maxima.org/member.php?...oster&t=379486
Cardomain Link
http://www.cardomain.com/id/red92maxima
Matt = Matt93SE
Profile Link
http://forums.maxima.org/member.php?u=46
Cardomain Link
http://www.cardomain.com/id/matt93se
oh and adjusting fuel pressure alone is not a very accurate way to tune a car, but yes it works, just be careful
Old Mar 10, 2005 | 07:32 PM
Cliff Clavin's Avatar
Way out West
Hahaha, I wish I had the same dyno numbers as Matt!
Probably just the nice Aztec Red Max, though. But mine was in the calendar! w00t!!!
Old Mar 10, 2005 | 11:01 PM
has anyone taken this path before? has anyone gotten results? where can a get an adjustable FPR for our VE's?
I need answers! NOW!
I must know.
Old Mar 11, 2005 | 12:10 AM
MrGone's Avatar
Nismo FPR
or the sx7r rail fitting then an aftermarket FPR (sard/aem/whatever)
or I guess you can hollow out the factory FPR, but I haven't looked into that.
If you are only going to raise the FP, then you can leave the factory one alone, however if you want to lower it, you will have to remove/disable somehow the factory FPR.
As for your PM on the SAFC-II
http://forums.maxima.org/showthread.php?t=385357
Old Mar 11, 2005 | 09:52 AM
subs1000w's Avatar
this is where i bought mine
http://performancenissanparts.com/ca...products_id=96
you could also get it here
http://www.courtesyparts.com/Merchan...=22670-RR580US
as for 5-10 hp it would depend on how rich you were and i would also suggest getting a FP gauge you could get one under your hood for 20$ and about 5$ in fittings that way you could see how far your adjusting the regulator
Old Mar 12, 2005 | 12:00 AM
well i have the JWT ECU, and i'm running really rich. I figured i'd lean my car out just a little bit to see what happens. In order to do that i need an adjustable one right?
Old Mar 12, 2005 | 09:59 AM
eric93SE's Avatar
Any fitment issues?
Old Mar 12, 2005 | 06:28 PM
subs1000w's Avatar
Originally Posted by eric93SE
Any fitment issues?
nope the only thing you may have to do is extend your fuel line or vacume hose
Old Mar 13, 2005 | 09:25 AM
eric93SE's Avatar
Easy enough
psing23
Mar 21, 2001 03:25 PM
psing23
Feb 3, 2001 06:50 AM
mingo
Jan 26, 2001 10:24 PM
Stillnmax
Sep 26, 2000 07:50 PM
Stillnmax
Sep 24, 2000 07:54 AM
