Quick temp question
Old Mar 12, 2005 | 12:29 AM
Brendan's Avatar
Quick temp question
Quick one guys, my heat and defrost takes a while to heat up, longer than usual, and when im at a stop it tends to cool down a bit until i start movin again, is this simply thermostat?
Old Mar 12, 2005 | 01:01 AM
Wiking's Avatar
One possibility. Q.: Does engine cool (see gauge) or only cabin??
Most probably a leak, cooling liquid level down, core heater valve vacuum (15.) hose leaking, thermostat, etc.
Leak means also air bubbles.
Seek for leaks, correct, fillup, bleed (Bvalve at 7.), vac hose...
Check for more info:
Old Mar 12, 2005 | 01:04 AM
Brendan's Avatar
gauge reads normal, i'll check it out tommorow since itll obviousy be snowing again and sucks to work on your car in the snow.. thanks man
Old Mar 12, 2005 | 01:10 AM
Wiking's Avatar
Have not experienced, but they say bleeding is PITA in maxima. See stickies.
I drive one hour with smtg bleeding in extreme cases to get all air out... Btw. Air might be the only problem.
Mar 12, 2020 12:06 AM
fastcarny
Oct 6, 2015 10:42 AM
97_GXE
Sep 15, 2015 06:47 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
