what is it, why is it running
Old Mar 12, 2005 | 06:37 AM
SSTEIN5252's Avatar
I have a 92 GXE. On the passenger side , next to the fender, is a silver colored rectangular shaped thing. It has serveral small metal hoses coming from it. It makes noise like it is running or pumping something after the car shut off. I believe it drained the battery because I needed to jump start the car.
Can some one tell me what this is and should it keep running after the car is turned off?
Steve
Old Mar 12, 2005 | 06:43 AM
«§»Craig B«§»'s Avatar
sounds like your ABS actuator
no it shouldn't be running after the car is off
Old Mar 12, 2005 | 08:31 AM
SSTEIN5252's Avatar
When I shut the car off last nite the noise was there. This morning I tried to start the car and it did start. Ran it for about 15 minutes and shut it off. No sound. Any clues as to what this might mean?
Can an abs actuator be fixed or do you need to buy a new one?
Steve
Old Mar 12, 2005 | 09:01 AM
GreenMaxVE's Avatar
The same thing happened to me a few years ago. It started draining my battery, so I pulled the 3 plugs that go into the front of the abs actuator. I left it sit over night unplugged. Plugged them back in the next morning and haven't had a problem since.
Old Mar 12, 2005 | 11:37 AM
Wiking's Avatar
Plugging/unplugging clears also the contacts. That should be done also with the ABS computer in the trunk. I took that box off, cleaned contacts and inserted minuscle bits of contact grease in ecah pin. Now works mucho better.
Originally only some (!?) ABS connectors had this grease, I have now added to all system connectors.
Old Mar 12, 2005 | 07:28 PM
internetautomar's Avatar
mod or sell?
ABS is tunning even after ignition is off sometimes, probably a bad relay (had the same problem on a J30) swap out the relay and you'll probably be fine
Old Mar 12, 2005 | 11:00 PM
Wiking's Avatar
Where is that relay located?
Old Mar 13, 2005 | 07:24 AM
mod or sell?
in the relay block underhood
Old Mar 13, 2005 | 08:10 AM
Wiking's Avatar
under water container:
fog lamp
inhibit
rad fan3
rad fan2
rad fan1
ascd
air con
bulb check
horn
wiper
...small box besid batt:
engine cont
a/theft
????ABS????
Edit: checked out from schema. There are TWO relays in the ABS assembly. ABS pump motor relay & actuator relay.
Old Mar 13, 2005 | 09:05 AM
SSTEIN5252's Avatar
What is the last post mean? Where is the relay?
Old Mar 13, 2005 | 09:23 AM
Wiking's Avatar
Copy of Edit: checked out from schema. There are TWO relays in the ABS assembly. ABS pump motor relay & actuator relay.
There are TWO relays in the ABS assembly. "On the passenger side , next to the fender, is a silver colored rectangular shaped thing. "
captchaos
Mar 15, 2016 12:18 PM
junito1
Sep 23, 2015 12:14 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
ballerchris510
Sep 10, 2015 09:35 PM
