where can i get a camber kit?
Old May 4, 2001 | 06:18 PM
flyry110's Avatar
where can i get a camber kit? I"ll probably want front and rear.
Old May 4, 2001 | 06:36 PM
ghostmax's Avatar
Hey,
8ball sent me this:
"The camber kit that i have was purchased from LightningMotorsports.com, it's the only one that i could find. HINT: don't bother with the front kit it doesnt hold. The kit is made by ingalls."
I checked and I think that the price was around $120 or so. Good luck.
Old May 6, 2001 | 06:16 PM
FiSH's Avatar
Flyry...
I ruined two tires in a month because I didn't get a camber alignement after lowering my car. I definately recomend that you adjust your camber but you don't need a camber kit to do this. The maxima, well at least mine, has slotted something or others so that the camber could be adjusted without the kit. So just go to a tire garage and tell them to align your camber and they should be able to do it no problem. The kit was available at my garage for about 30$ and it was even in stock but they said it wasn't necesary.
Oh and by the way rear camber is not adjustable but it isn't imporant because there isn't much weight on them in comparison to the front.
Hope this helps,
Dave
Old May 6, 2001 | 06:35 PM
flyry110's Avatar
Re: Flyry...
rear camber is not adjustable!!! hmmmmmmmm that is not good.
Old May 6, 2001 | 07:35 PM
Chris Gregg's Avatar
Get Off My Lawn
On the rear, you can either have your struts heated and bent or buy some Ingles camber kits. There are other, cheaper kits out there. I talked to a guy the other day that had the rear kits cheaper than the Ingles, same concept. The front can be done with camber bolts or heated and bent. The bolts for the front run about $60-70 cheapest I've seen, might be others cheaper (?).
Old May 6, 2001 | 11:40 PM
Brad's Avatar
[http://www.stillen.com]my friend
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
