innerglow
Old Mar 13, 2005 | 04:52 PM
expressinme's Avatar
innerglow
does the innerglows or the inner lights have a fuse to it? all my inner light not working at all
Old Mar 13, 2005 | 05:17 PM
Cdg2125's Avatar
Yeah there's a fuse in the box next to the drivers door. Should say on the removable panel which fuse to take out. I think it's like....the third from bottom on the left side. That may work.
Old Mar 15, 2005 | 05:06 AM
checked the fuse, its good
Old Mar 15, 2005 | 06:20 AM
Wiking's Avatar
- fuse got just good looks -or- have u actually measured it?
- what exactly is included in your definiton of innerglo?
Old Mar 15, 2005 | 06:37 AM
markmaxima's Avatar
it's not the fuse, its the switch, the switch burnt out, you can rewire it to another power source ir buy a new set of indaglos.
Old Mar 15, 2005 | 06:46 AM
when i turn on my headlights the innerglows dont come on, and the clock and digital a/c dims out and goes away. I can still see the clock but the a/c is completely gone until i take off the headlights. The only dash lights that work is, my cd player, and my light thats in my ash tray. I replaced the switch that turns on my headlight, and its not that. Cant think of anything else before takin to to my mechanic. Anyone suggest anything else, i will appreciate it.
Old Mar 15, 2005 | 06:53 AM
Wiking's Avatar
... Anyone suggest anything else, i will appreciate it.
Swap ALL fuses, regardless of looks. Really cheaper than mech...
Dash lights are connected with rear lights as safety feature. As they're out, dash lights are out. Open, check for shorts in both rear assemblys, wrong bulb/installations...
Main light switch burned contacts? Open, clean -or- Swap.
Old Mar 15, 2005 | 09:24 AM
i checked the switch its not it, so today imma change the fuses and check for wrong bulbs or shorts. thanks a lot hope it works
Old Mar 16, 2005 | 04:03 PM
my brake lights work fine, what can be the problem
Old Mar 16, 2005 | 05:42 PM
markmaxima's Avatar
i wish you luck
expressinme
Mar 6, 2005 12:59 AM
