Security Alarm Light...
Old Mar 15, 2005 | 06:43 PM
Raskolnikov's Avatar
Just wondering if the stock security light in my '91 SE is supposed to blink when the car is off. Seems like it should...but mine doesn't. My friend's '93 SE does...just curious if mine is defective or they changed for the later models. thanks.
Old Mar 15, 2005 | 06:47 PM
mtnbikeair's Avatar
Maybe your bulb just burned out? It is a 14 year old car, i would check that as a posibility.
Old Mar 15, 2005 | 08:07 PM
naw, the bulb is good...it works when the alarm is being set when I lock the car and all...but then it just goes off. any ideas anyone? is this normal?
Old Mar 16, 2005 | 02:52 AM
nubiannupe's Avatar
OG Maxima.org Member
I'm kinda unclear on what you're referring to, so correct me if I'm wrong here...
What you're saying is, when you lock your car, the light is on but then goes off?? THAT is normal.
If the door is open and the light is blinking (with the car turned off), THAT is normal as well.
If the door is closed and the light is NOT blinking (i.e. SOLID - with the car turned off), THAT is normal, too. Of course, that goes back to my first sentence, where the light goes off after about a minute.
Now, if the door is open and the light is NOT blinking or solid (with the engine off), then you have issues. Then, I'd check the doors, hood, or trunk for a faulty pin switch. Rarely, the door lock module is to blame. But I'd look at the pinswitches first off.
Old Mar 16, 2005 | 05:22 PM
cool...well i was just curious if it was supposed to be a flashing 'warning' light...like some alarm systems have with a little red LED light. But if it's SUPPOSED to blink, and then just go off after a minute...then all is well I suppose, but, it does blink in my friends '93 when its just sitting there. was that something they changed? thanks again though.
Old Mar 17, 2005 | 10:27 AM
Geerhed's Avatar
Moved on to BMW's :(
In my 90SE, the light blinks when the car is shut off, but something (a door, trunk, hood) is still open -- like the security system is ready to be set but something is still in a 'fault' position.
Once the doors/trunk/hood are all shut and the door is locked with the key, the light comes on solid for a few moments and then shuts off, signifying that the alarm is set. I'm pretty sure it details this in the owner's manual.
Old Mar 17, 2005 | 07:09 PM
vansskaterfreek's Avatar
i have a 1991 maxima se, the security light blinks for about a minute when i turmn the key to lock doors but it does come on and shut of, so i dunno
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
Junebug1701
Sep 25, 2015 01:54 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
