car puttering in low rpm in drive
Old Mar 17, 2005 | 03:09 PM
Dj Paul's Avatar
my car is shaking slightly in low rpms but only in drive and reverse. you can still tell its there in neutral and park but its not that noticable. Do you think i would need a new fuel pump? everything else on my car i have fixed. i put in the coolant sensor and everything else is fine. Before today the car would putter on startup and then start to run fine. It also cut out a few times. but now its just puttering constantly and is really annoying. the timing is fine. Just to make sure i even plugged in the old knock sensor harness cuz it is not totally bad yet. but that was not problem. What do you all suggest i do because i dont feel like buying a fuel line gauge. but i might have to. Is there a way to test it electrically? cuz i never have.
Old Mar 17, 2005 | 06:29 PM
internetautomar's Avatar
mod or sell?
um, that sounds like a misfire to me.
Old Mar 17, 2005 | 06:50 PM
Dj Paul's Avatar
yes, i checked my spark plugs, carbon deposit on num 4. I was just seein if people had ideas cuz it felt like when you take out the fuse to the fuel pump.
Old Mar 17, 2005 | 07:10 PM
mod or sell?
did you check to see if it was the coil ?
it's more than likely the injector though
Old Mar 18, 2005 | 07:04 AM
Dj Paul's Avatar
i fixed it. it was the spark plug. i adjusted my mixture cuz i think it was running too hot. Im eventually gonna get hotter plugs to accomodate for it.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
egali045
Aug 16, 2015 01:19 PM
