Quick Cutting Question
Old Mar 30, 2005 | 12:23 PM
Scope's Avatar
Im izz sexay
What's a good tool that can cut through the metal for installing my cefiro's. I tried using the dremel and it basically stop within a half inch of cutting. I am going to get some cutting disks on friday for the dremel and see if that helps. Any recommendations on this?
Old Mar 30, 2005 | 12:44 PM
Drivin Maxima's Avatar
i would say either a saw-zaw, cutting wheel or even a plasma cutter if you have access.
Or.......you could just run to the store and pick up some sheet metal shears and start knawlin away at it
Old Mar 30, 2005 | 02:02 PM
tripleGmax's Avatar
id say any rotary tool like a dremel will work....dunno off hand if they make bigger discs but i assume they do. saw-zaw could do the trick too.
Old Mar 30, 2005 | 02:13 PM
internetautomar's Avatar
mod or sell?
SawzAll!!!!!!
Old Mar 30, 2005 | 02:17 PM
tripleGmax's Avatar
i like to pronounce is saw-zaw, sounds cooler
Old Mar 30, 2005 | 04:08 PM
goon9's Avatar
Working on my headlights again at the moment, I've just been prying metal apart with chanel locks, lol.
But a nifty tool is a Body Saw, it's actually made for cutting into your body. But, it runs on air... Which i don't have so I'm stickn with my dremel and trsuty channel locks.
Old Mar 30, 2005 | 04:15 PM
«§»Craig B«§»'s Avatar
I got a nice little Ryobi grinder for $30 the other day at Home Depot and then a cutting wheel for it for $4. It worked great for cutting through metal. I used it for cutting a hole in the inside of the door on my prelude (power locks and keyless entry )
When I did my BMW lights, I actually just used vice grips after I made a small cut and then twisted the metal out of place pretty easily like opening a sardine can.
Old Mar 30, 2005 | 04:37 PM
Scope's Avatar
Im izz sexay
I have the same rotary tool. I am going tomorrow to walmart and see if they have some cutting wheels. I was going to on friday but I want to put my Cefiro's in. The only thing that sucks about them is that the whole assembly holding the corner light also has to come off. I looked at the headlights as they rested on my bumpers and I knew that they are gonna be a PITA. Oh well I'm goona try and get this right tomorrow Thanks for the input.
Old Mar 31, 2005 | 04:10 AM
rrrfoma's Avatar
I'd use 2" cutting wheels (dremel tool) for this job. There are not "dremel" brand but come with an adapter to fit in dremel (maintain higher rpms. i.e. 25-30K).
Old Mar 31, 2005 | 06:23 AM
white90se's Avatar
i use my rotozip...works wonders...rpms are alot higher then the dremel...and my dremel broke
shilov
Feb 19, 2024 09:40 PM
Mar 12, 2020 12:06 AM
DBear
Sep 14, 2015 08:33 PM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
Johnny9595
Sep 3, 2015 05:18 AM
