Screwed up. Turn signals aren't working...
Old Apr 4, 2005 | 07:23 PM
imported_Maxima_Mike's Avatar
So I was trying to do the cornering rewire ( the one where the orange bulb flashes with the turn signal) and I had some problems at first but eventually got everything connected. When I went to test it, I flicked the turn signal to the left and I heard a buzzing sound and nothing happened. Now both signals don't work. Looking at the diagram Craig made more closely now I think I know what I did wrong, but I reconnected everything back to stock and they still don't work. Any help is greatly appreciated.
Old Apr 4, 2005 | 07:29 PM
nelledge's Avatar
"I'm just sayin'..."
Obviously, buzzing electrical noises are not good. Did you make sure you didn't blow the fuse? I know it's simple, but sometimes we forget. Just in case you need the diagram.
Old Apr 4, 2005 | 07:32 PM
Michael's Avatar
Back in a 3rd Gen.
you may have blown the flash relay or whatever that piece is called (the piece that makes them blink) or its just a blown fuse.
Old Apr 4, 2005 | 07:34 PM
acutually, I didn't check the fuses. I'll go do that now. Where is the relay though?
Old Apr 4, 2005 | 07:47 PM
Michael's Avatar
Back in a 3rd Gen.
its called a combination flasher unit in the FSM. Its not actually a relay. Its located at the M29 connection which looks to be in the center of the car above the ECU or in that general area.
Old Apr 4, 2005 | 07:55 PM
tripleGmax's Avatar
so its the CFU in the FSM @ M29 near ECU hehee
Old Apr 4, 2005 | 07:59 PM
markmaxima's Avatar
hopefully for your sake it is just a fuse, you may have shorted something out.
Old Apr 4, 2005 | 08:25 PM
Good news, the fuse is blown. But I lost that little grabber tool that comes on the inside of the fuse box cover, so I can't check to see if the fuse is the only problem I have.
Old Apr 4, 2005 | 08:28 PM
markmaxima's Avatar
wish you luck, be careful with the wires.
Old Feb 5, 2011 | 08:02 PM
Venzo's Avatar
My blinkers don't work! the bulbs are good, the fuses are good, and i even (through much frustration) located and replaced the flasher relay unit. The problem is...i still have no blinkers!! I'm not sure what to do next. Any suggestions!??
I read, in a forum i can't seem to find again, something about a 4-way flasher, but i can't seem find anymore information about it so I'm not even sure if a 4-way flasher really exists. Any help would be great!!
boomerbrian
Oct 31, 2018 10:25 AM
captchaos
Mar 15, 2016 12:18 PM
LtLeary
Sep 14, 2015 12:33 PM
minsbang
Sep 11, 2015 08:48 PM
