Grease inside axle boots
Old Apr 13, 2005 | 02:18 PM
garbury's Avatar
What kind of grease is inside the axle boots? One of the boots is split, and a greyish grease is coming out. Will any multipurpose grease work, or what have you guys used?
Old Apr 13, 2005 | 02:19 PM
Jeff92se's Avatar
I'm needing a caw
Stores have grease specifically for this. It's included in most boot kits
Old Apr 13, 2005 | 03:02 PM
eric93SE's Avatar
You need to rebuild the axle, the new boot should have grease with it. Its not a very difficult job, but does require an impact gun to get the axle bolt off. Adding grease is not the solution.
Old Apr 13, 2005 | 04:20 PM
nelledge's Avatar
"I'm just sayin'..."
Just in the off-chance someone needs the grease by itself... it is available. Perhaps, one didn't install the boot tight enough on original replacement and it oozed out. Precision (NAPA and Oreilly I believe) has a part number for the cv shaft grease listed seperately. It's cheap enough. Do not use just any type of grease. Bad things later down the road. Ok. Bye.
Old Apr 13, 2005 | 04:58 PM
garbury's Avatar
thanks guys, yeah i have the axles off as I took off the tranny. The passenger side input boot is cracked, so should i just replace the entire axle or put on a new boot. Dunno if its worth the hundred bucks or so when they worked fine before I took the tranny off.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
