is there a "how to" for resistor mod
Old Apr 17, 2005 | 09:45 PM
Jeff583's Avatar
is there a "how to" on the resistor mod, because i wanna test my knock sensor to see if thats my power lag problem
Old Apr 17, 2005 | 10:13 PM
MrGone's Avatar
first problem is calling it a mod.
second, are you well versed and fully able and willing to swap engines yourself, or financially able to pay for a mechanic to do it?
Old Apr 17, 2005 | 10:51 PM
Cliff Clavin's Avatar
Way out West
the KS bypass (resistor) is not recommended. If you do it, it is entirely at your own risk.
ask one of the guys that swear by it. They can answer your question. Look back a bunch of threads or pay to become a donating member and search.
Old Apr 18, 2005 | 06:52 AM
internetautomar's Avatar
mod or sell?
it is not a mod.
it is a test procedure and should not be left on for anylength of time.
you also need to run 93 octane on it to be safe.
Old Apr 18, 2005 | 06:57 AM
blacks92seAuto
I am currently using the resistor DIAGNOSIS is what I call it...I have been using it for 4 days now....my gas mileage is back up....once this tank is complete I'm going to take the resistor out, and hook up my KS again...and run the same brand of gas,,, I have been using bad gas for like a year now, and I think it slowly clogging my injectors, so I think that was my prob, not my KS...
Everyone that says don't do it because it can screw your motor up, is absolutely right. I would NOT reccomment this DIAGNOSIS unless you are at least 90% sure your motor is in tip top shape and the only thing wrong with it is the possible bad KS...otherwise I would reccommend going to the dealership and spend 90 bucks or so for them to PROPERLY test the KS
Old Apr 18, 2005 | 07:22 AM
Matt93SE's Avatar
STFU n00b!
you can properly test the KS with a simple multimeter, guys... it's just a freaking piezo element inside a plastic case. should read approx 500k ohms if it's working. If it reads an open circuit, then it's dead. simple as that.
Old Apr 18, 2005 | 08:17 AM
mod or sell?
an open circuit reading can also indicate a bad harness
Old Apr 18, 2005 | 08:35 AM
blacks92seAuto
what about heat soak? I thought heat soak could make the KS send false readings when the engine has been driven for a while?
Old Apr 18, 2005 | 09:25 AM
Jeff583's Avatar
isn't there a place other than under the intake to place the knock sensor, i mean it should work anywhere on the block, cuz i need to replace my knock sensor now and i plan on doing a rebuild this winter so if i could just put it somwhere else for know would be great
Old Apr 18, 2005 | 10:47 AM
MrGone's Avatar
So? Eitherway you are going to have to do the same ammount of work. Might as well replace them both when you are down there.
Your point sucks
Old Apr 18, 2005 | 11:15 AM
mod or sell?
you are correect that the labor is basically the same. but part cost is different
Old Apr 18, 2005 | 11:30 AM
Wiking's Avatar
Yea, its bs to test it with multimeter. Only way is to see actual ignition timing during drive and load. The nissan dealer tester supposedly is capable of that.
Without tester, unplug KS connector, install 0.5MOhm resitor on. Drive with high octane. My opinion is that on VGE this is ok, but on VE one must be more careful not to ruin the engine. I've been using the bypass, and will never bother to replace the KS... as I use 95 always. The only possibility for me to get lower octane, would buy a bottle here at colorado, and try to smggle it back at home...
Heres howTO pic and site (seems to be down just now...):
http://www.cardomain.com/memberpage/748507/1
knight_yyz
Nov 1, 2015 01:34 PM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
ballerchris510
Sep 23, 2015 08:46 PM
