Fuel Injector Removal
Old Apr 21, 2005 | 06:40 PM
KEhrhardt's Avatar
Anyone have any ideas or tips on how to remove a stubborn fuel injector from a VE? I have one on the #3 cylinder (yes under the damn intake plenum) that just doesn't want to come out. Any tried and true techniques for removal you'd like to share? I've tried PB Blaster, spinning, wiggling, etc.... I'm ready to drill the SOB out!!! Help!!!!
Old Apr 21, 2005 | 06:47 PM
mtnbikeair's Avatar
Well first off, calm down, you will harldly ever make progress being mad at your car. At least i dont anyways. Why do you need it out so badly and in a hurry?
Old Apr 21, 2005 | 06:52 PM
internetautomar's Avatar
mod or sell?
pull the whole rail out and tap it out from the bottom up
Old Apr 21, 2005 | 08:12 PM
KEhrhardt's Avatar
The intake plenum is apart already and the injector is sitting there ready to be removed. I just replaced the number 1 injector one month ago. Probably should have done all three on the rear bank at that time. The first injector came out rather easily. This one is a major pain. My daughter drove it around for awhile before I got the call 'oh dad the check engine light is on again'! The cylinder was loaded up with fuel, so I bet that might have had a suction effect on the injector making it harder to be removed..... SUCCESS!! I finally was able to get it out by tapping a small screw driver between the injector body and the fuel rail and *gently* prying the injector out of the fuel rail. Well, not the best solution, but it worked. Hope this helps someone else out.
Old Apr 21, 2005 | 08:24 PM
Jeff92se's Avatar
I'm needing a caw
You will ruin the pintle cap that way
Old Apr 21, 2005 | 08:46 PM
Minty91GXE's Avatar
i had a tough time with this too. i wrapped mine in cloth and then used locking vice grips to get a firm, but not firm enough to break the plastic, grip on the rectangular plastic block (the widest direction - so as to not be touching the plastic around the pins), took a lot of fine adjusting to get it just right, then held the vicegrip low near the plug and wiggled and pulled till it popped. u did depressurize the fuel system right? well its too late now anyway.
Old Apr 22, 2005 | 05:13 AM
KEhrhardt's Avatar
Hi,
Yes, I did depressurize the fuel system by pulling the fuel pump fuse and cranking the engine a few times. Maybe not enough though. I did the same thing with the vise grips, but used those ratching pliers from sears without the cloth (dumb) and I was starting to break the plastic block on the old injector. That is when I started to get worried and thought I would post to see what others have done. Thanks for the responses.
Old Apr 22, 2005 | 06:11 AM
mod or sell?
who cares if you're placing the injector with a new/used one
Old Apr 22, 2005 | 07:20 AM
-shock211-'s Avatar
that's how i've done it about 4 times now on my vg
i put a socket on it that is just larger in diameter than the pintle cap. that way the pintle cap doesn't break while i tap the sucker out.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
