Possible Blown Fuse?
Old May 2, 2005 | 07:49 PM
MaximaJohnny's Avatar
Hi guys haven't posted in awhile just had a quick question. The other day I got in my 3rd gen and my Headunit, Clock, and seatbelts all werent working. It seems like maybe a blew a fuse but i looked under the dash and didnt see any bad fuses. I was wondering if there was anywhere else I could check ? Oh ya my power antenna is stuck all wayy extended now hmmm.
Old May 2, 2005 | 08:22 PM
goon9's Avatar
Make sure your battery is connected. I hated when I forget I unhooked mine...
Old May 2, 2005 | 09:10 PM
Wiking's Avatar
...how did u manage to hit the road?
Old May 3, 2005 | 03:02 AM
Im pretty sure it isn't the battery lol.
Old May 3, 2005 | 03:46 AM
michaels'max's Avatar
There is a fuse that is related to the seat belts and the clock. I don't know about the head unit and the antenna. I had a problem where my inside lights my seatbelts and my clock were all not working properly. My clock turned on, but would reset everytime the power was turned off. My seatbelts would only roll up and down when the ignigition was on, and my inside lights would not turn on. This all was due to a fuse, I think it was called electron something or other. Sorry I don't know which one exactly but you may want to check your fuses again. Otherwise, maybe you shorted something else out. Sorry I'm not much help.
Old May 3, 2005 | 03:50 AM
Wiking's Avatar
Originally Posted by MaximaJohnny
Hi ... and didnt see any bad fuses.... if there was anywhere else I could check ...
Swap all fuses ---> seeing is not same as measuring.
Check from FSM schema... http://www.cardomain.com/memberpage/748507/1
Old May 3, 2005 | 04:53 AM
pito11213's Avatar
Also for the seat belts I believe there is a fuse under the hood for that system.
Old May 3, 2005 | 05:11 AM
nelledge's Avatar
"I'm just sayin'..."
Check the fuses. Rather than spend your time looking at each one, use this diagram. That link can be found in the 3rd GEN FAQ section. Skim through this section in your free time. Tons of information.
Old May 3, 2005 | 06:28 AM
bhunter's Avatar
Electron batt fuse. ( Basically direct to battery)
Old May 3, 2005 | 06:54 AM
LuckyNYC's Avatar
Thank you, I needed that as well and i knew I saw that somewhere around here.
leatherneck
Sep 30, 2015 09:16 PM
conansriver
Sep 16, 2015 12:17 PM
Maxie40
Sep 14, 2015 11:28 AM
jwright36
Sep 8, 2015 11:45 AM
