Coolant Temp Sensor
Old May 10, 2005 | 05:27 PM
MAXI's Avatar
Coolant Temp Sensor
Whats the difference between the blue one and the red one?
i had a blue one in there and it seems like even the temp is on the "hot" side, the fans never turn (yes...if i disconnect this, the fans turns)....so i went and replaced this with a red one.
when i installed and started the engine, it hesitated and my CEL went "on" for a minute then went away then idled normally. I shut off the engine, then after 5mins, I started it again....again the engine hesitated or about to stall but it went down to normal...weird.
Old May 11, 2005 | 12:05 AM
Wiking's Avatar
Originally Posted by MAXI
Whats the difference between the blue one and the red one?....
Blue reflects light on different wavelenght than red...
Max (VE and VG) has one engine temp sensor which ECU uses in engine ctrl. Dunno about your colors, but resistance is the only thing that matters to ECU. Cold is about 2.6kohm, warm is near 1k (VGE).
Another engine temp sensor is used for greenpiss: EGRC
VG30E:
Old May 11, 2005 | 07:50 AM
DanNY's Avatar
Ad·min·is·tra·tor
the 2 wire one is for the ECU/fan signal.
the 1 wire one i believe is for the dash gauge.
Old May 11, 2005 | 08:09 AM
Wiking's Avatar
Old May 11, 2005 | 08:21 AM
MAXI's Avatar
Danny,
yes, its the 2 wires that i replaced. i may have a dud here.
Wiking,
how do you test resistance?
Old May 11, 2005 | 08:54 AM
Wiking's Avatar
with a 10€ gauge.
- Select Resistance meas scale,
- Engine temp: take conn out, one probe on pin, one on engine =gnd
- EGRC: take conn out, one probe on pin1, one on pin2
It migt be ok to leave conn in while measuring...
Old May 11, 2005 | 10:01 AM
eric93SE's Avatar
Originally Posted by Wiking
the US version only uses EGRC temp sensor on the california model.
my03maxima
Jul 28, 2024 07:40 AM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
