D2 coilovers
D2 coilovers
has anybody heard of D2 and their coilovers. granted it is 1300 dollars but what do you guys think.
http://www.andysautosport.com/produc...scat=Coilovers
There's only 1 slight problem. Those coilovers are designed for a A31 Maxima. You have a J30 unless you got yours from overseas. And there is that much of difference between our cars. Sorry to burst your bubble.
But give Matt some time. He's working on a coilover setup for our cars right now. I'm going to be trying out a different set later this year to see what the long term effects are.
yea i didnt know it was for the overseas model. oh and dont worry about busting my bubble i dont have $1300 yet and i would probably that to a better cause. my suspension is hurting but not that bad lol. my intrax springs sag in the rear alot from the system, and i think i killed my tokiko's
Matt is still working on coil-overs? Yikes! I gave up on that years ago. With a nice set of Koni's and eibach's you will out handle a coil-over set up especially with the money left over to buy anti-sway's and sub frame bracing. I know someone with a stanza had a coil-over set-up which i am almost possitive it has the same suspension set-up as a max. Also maybe the 3rd gen group needs to get a company to make a 1mm+- bigger anti-sway bar kit that is adjustable and hollow!
Originally Posted by Joe Fontinyatz
coil overs? hhmm.. not same thing as coil springs. whats the difference?
http://www.tein.com/stsp.html Coil spring and http://www.tein.com/srdamp.html coil over set-up
he started making new goodies
Same with Jeff hehehh (13" cobra BBK using 300zx calipers)
OG
damn havent seen you in a while
the ride quality on the Eibach//Koni combo is about the best you'll find, but you can still corner significantly better if you go the coilover route and up the spring rates... Which is of course what makes the ride quality so much worse on the coilover setup..
but yes, there are definite improvements available out there.
but what if you had the sway bar and subframe and coil overs ... wouldnt that work better?
a coilover uses standard diameter springs that you can order from any race shop with any spring rate and free length you want. you can adjust ride height, preload, and often shock damping and camber/caster as well...
thus you can set the coilovers to what you like and what makes the car handle the best for your application.
A regular macpherson strut is the same basic design, but it uses springs that are specific to that particular car, and often trim lin.e (the SE springs on a Maxima are slightly stiffer than GXE springs, but they both fit in the same strut assembly.)
NewMax03
Oct 7, 2015 08:27 AM
NismoMaxi02
Oct 4, 2015 09:09 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
