radiator fan fuse keeps blowing
Old May 23, 2005 | 12:26 PM
mofoaka's Avatar
i need some help guys, my radiator fan fuse keeps blowing, in result, my a/c stops working. its getting really annoying, i've never wired any thing for the car so what could be the problem? thanks
Old May 23, 2005 | 01:25 PM
Drivin Maxima's Avatar
sounds to me like a short to ground....
Old May 23, 2005 | 06:54 PM
mofoaka's Avatar
well it happens only once in a while but i don't even know where to begin to ground the shortage.
bump to my question
Old May 23, 2005 | 07:01 PM
Alex_V
One of the wires that goes to the motor prolly ate the the insulation and is shorting out or your fan motors are going bad. If you want to replace them i have a whole radiator and shroud and fans FS
~Alex
Old May 24, 2005 | 10:22 PM
mofoaka's Avatar
umm which wire goes to the motor that connects to the radiator fan and a/c unit?
Old May 25, 2005 | 12:25 AM
Wiking's Avatar
ECU controls the fan relays; shorted relay/wiring in the box? Checkout, get replacement from junkyard. Whereever the box might be, its cover says the function, VGE:
Old May 25, 2005 | 09:01 AM
mofoaka's Avatar
thanks wiking that actually helps a lot. i'll check the wires and relays there asap!!
Old May 25, 2005 | 09:19 AM
Wiking's Avatar
One relay for one fan low speed, another relay for second fan low speed, third relay is for high speed (both). Want a schema? Check my w-page 1.; links.
Old May 25, 2005 | 01:09 PM
mofoaka's Avatar
oh, one thing, mine is a VE any difference in the relays?
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
leatherneck
Sep 30, 2015 09:16 PM
