what is this vaccum hose for?
and just to let yall see my polished valve cover.. stupid stud on the head snap so i'll have to get another one... do you think i can run the engine with one missing stud on the valve cover?
Originally Posted by mofoaka
[IMG]... do you think i can run the engine with one missing stud on the valve cover?
Take a luki of u climate ctrl valve at: http://www.cardomain.com/memberpage/748507/8
15. ...........Vacuum line from intake; hose contains small oneway valve.
14. ............Magnetic valve for vacuum control.
14b. ..........Vacuum line link from magnetic valve to vacuum actuator.
14c. ...........Vacuum actuator arm moves the actual water hose (7.) valve.
14d. ...........Inset: (Mechanical) Water Valve is 'hidden' under the assembly.
16. ...........Electronic control wiring from cabin. Note the diode -mark on the connector.
Edit: ...The stud: as long as it keeps saddamoil inside its ok.
HerpDerp1919
Sep 29, 2015 02:02 PM
