Clean those connectors.
Old Jun 4, 2005 | 08:37 PM
rawmax1's Avatar
Tore the max down today. Did Timing belt(very loose). Connectors to injectors/Maf/tps very rusty. Only good connectors on car were the ones going to transmission. Took me about one hour to get crank sprocket off to change crank seal. Monday i will clean throttle body/iac valve very dirty even after intake cleaning from a about 2 weeks ago. Looks like it cleaned some chambers of intake plenum but not all. Well to make a long story short I narrowed the rough running and non start to bad connections and loose timing belt. I will button car up by end of the week
Old Jun 4, 2005 | 10:33 PM
eric93SE's Avatar
hey great work, few people understand the problem with corroding connectors. I've soldered a bunch of them (MAF, Temp, VTC solenoids). Most people assume their 10-15 year old car still makes 160,190
Old Jun 4, 2005 | 11:19 PM
internetautomar's Avatar
mod or sell?
my 26 yr old still makes it's 185
Old Jun 5, 2005 | 05:29 AM
Wiking's Avatar
...theres nuts, bolts, cams and axles where the complicators sit nowadays. Thats why.
Old Jun 5, 2005 | 05:49 AM
Pervis Anathema's Avatar
Come again?
Old Jun 5, 2005 | 06:17 AM
mod or sell?
Originally Posted by Pervis Anathema
Come again?
he means that it lacks the computer and it's resultant bad connections, that can degrade over time like the max has
Old Jun 5, 2005 | 07:45 AM
Wiking's Avatar
...yess: diesels rule, those before 80's.
Old Jun 5, 2005 | 01:12 PM
subs1000w's Avatar
do you mean youve cut the plug off and soldered the wires directly onto the sensors terminals
Old Jun 5, 2005 | 01:42 PM
eric93SE's Avatar
YES, I drilled an eye hole in the terminal (by supporting it with a small piece of wood, drilling through the plastic and the terminal). On the VTC's and temp sensor I had to extend the wires.
Old Jun 5, 2005 | 11:40 PM
Wiking's Avatar
...now THAT will extend your mile-age for 20yrs or more!
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
