need help for a friend
Old Jul 13, 2005 | 04:37 PM
xlcrew's Avatar
I’m Back
i got a friend here in okc that needs help with her car. i'm going to look at it tonight but i was hoping that by giving you her description of what's happening could help me out. i don't know crap about 3rd gens and just a little bit more than auto's. so here it is
sometimes it wont let me reverse, its hard to shift it into drive (its an automatic) and sometimes it wont even get over 35 mph without going to 6000 rpm :-s i think its my transmission and i need someone to look at it before i take it to a shop
anybody have a guess as to what it is?
thanks
Old Jul 13, 2005 | 04:39 PM
internetautomar's Avatar
mod or sell?
trans fluid low
Old Jul 15, 2005 | 02:03 PM
xlcrew's Avatar
I’m Back
ok i looked at the car. the trans fluid was not low but it did look a little burned. we are going to get everything to do a flush real soon. my question is that when i had my 95 and had tranny problem i never had a problem with my car missing a gear like my friend is with her reverse. it kind of boggles me. so i guess we will try the tranny flush and see what happens
Old Jul 15, 2005 | 04:51 PM
eric93SE's Avatar
It could be shift linkage bushings. there are two nylon bushings one at both ends of the cable. The one below the shifter is accessed from above the cat. convertor heat shield. the other is easily checked where the cable meets the tranny, there is a metal clip that hold the cable on.
note: do not adjust the length of the cable, replacing the bushing will get the cable to its proper length. Also they only cost about $5 for both of them.
Old Jul 15, 2005 | 06:08 PM
maximagxe90's Avatar
do not flush the tranny if it has not been flush before,
if you flush the tranny you are going to get your self into trouble,
so i would recommend a drain and fill instead the flush,
you forgot to tell us how many miles is on the car, the model and the year,
Old Jul 15, 2005 | 07:49 PM
DGruber 58's Avatar
What is wrong with doing a flush? I was told not to flush my rad. because it might "force" a leak... which is total bs. If the rad can't handle a flush, i wouldn't want to drive the car. Just wondering if this is similar to your reason for not doing a tranny flush. If the trans can't handle a flush, is it really fit to be on the road?
Old Jul 15, 2005 | 10:30 PM
xlcrew's Avatar
I’m Back
sorry the car is a 93 gxe with 146,000.
Old Jul 16, 2005 | 12:59 AM
Wiking's Avatar
...and full of computers, sensors. They require more than excellent flawless good pwr supply.
Check here whattodo with gearbox computing↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓
Quickywd01
Sep 21, 2016 09:36 PM
The Wizard
24
Oct 1, 2015 08:47 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
carid
Sep 17, 2015 05:00 AM
jwright36
Sep 8, 2015 11:45 AM
