Broken Crank Shaft!
Old May 22, 2001 | 09:34 AM
xster
Greetings,
How about this one? The other day I was driving my 1991 Maxima up a hill. I just got over the crest of the hill - i heard a little "tink" and the car just quietly shut off. I towed it home the next morning and discovered that the car's crank shaft broke right at the pully. I took the bolt from the center of the pulley and the pulley itself off by hand (no tools)!
I had a friend/nissan mechanic look at it. He's trying to figure out why it broke (very strange for the crank shaft to break in that spot. There was a small chip on the pulley. Prior to this the car has 185 000 km's and ran like a clock - (except for one injector i had to replace recently).
I don't suppose anyone knows where i can find a new/good-used crank shaft for this engine? Or possible a good used engine???
I believe the valves are still OK - (lucky) that is why i think i would rather just change the crank shaft if i could get one reasonably priced.
Thanks,
Rob
Old May 22, 2001 | 11:32 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Check....
car-part.com
(OR)
http://www.actionsalvage.com/engine/...gineNissan.asp
personally I'd just swap in a new engine, seeing as how to replace the crankshaft you'll have to pull the engine anyways! you might be able to find a cheap low milage used engine for as low as $650-850 on either of these sites, good luck man!
Old May 22, 2001 | 11:39 AM
Jeff92se's Avatar
I'm needing a caw
It's probably not the crankshaft perse. What happended is that the pulley's key broke and damaged the slot on the crankshaft. Your crankshaft is not broken but damaged. I would see if the keyway is still in good condition(on the crank) Maybe you only need a new pulley key. But there is a good chance that the pulley's key wore the keyway out on the crank to a point where it's not fixable. Good luck.
Old May 22, 2001 | 12:32 PM
brubenstein's Avatar
Ford used these engines in some of their mini vans and had a problem with broken crankshafts at the pulley. It happens from the timing belt tension being set too tight.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
TKHanson
Nov 24, 2018 01:39 AM
zmcneely13
Sep 26, 2015 02:26 PM
