Transmission Problem: Auto slipped out of gear
I have an auto tranny, all stock, never had really any problems with it until 2 days ago when I pulled out after being stationary for a while and noticed I had no low end power in drive. It was accelerating so slow I knew something was wrong. When I got home I was trying to figure out the problem and noticed that when I put it in reverse it didnt move at all, even with a little gas. So by this time I knew it was a transmission problem.
With the car in park and giving it throttle the car would actually lurch forward slightly but never really move and the car would not move at all in Low gear(1). So I'm just casually messing around with it still in the driveway and I have it in reverse and with a little gas (not reving it high at all) the car jumps back into gear and I go flying backwards. Luckily I have a big empty driveway. So now the car is working like it should but what the hell happened? Anyone have anything like this happen to them? I am still gonna have a transmission shop look at it but it still boggles me to know what could have done it because I sure didn't mess with anything.
Also try adding the lucas transmission fix stuff...
I agree though about the electrical connecters since it doesnt make sense that all of a sudden it engaged and then works fine in all gears since,unless maybe the toruqe is acting up...
check the fluid and see if it is burnt up any though.
I got a similar transmission a couple weeks ago, after the car had been parked outside for a month. Then last night, it happened again. The car had ben parked for 24 hours. I noticed that in park, it was OK. No apparent problem. Then I shifted in reverse and the engine stalled. I restarted, then put the lever in drive. The car was almost stalling so I give some gas, with the handbrake on. I also noticed that the Idle speed was going from 6-7 hundred RPM to perhaps 1500 repeateadly. I took a chance to go on the road and drove 25-30 miles, going through the gears automatically and sometimes manually via 1, 2 etc. with overdrive oN/Off, and also playing with the Comfort/Power button. Can anyone shed some light on this?
Originally Posted by Alex_V
I....(we all know it wont be that straight forward
)every other alex will suggest dropit and shell 2k$ ... "we all know now it wont be that straight forward..."
The problem sounds like hydraulics; hopefully only stuck Line pressure valve. I would check TCU pin1 that it gets ctrl >0.5V when problem becomes acute...maybe open solenoid assy and why not then install the valve upgrade kit.
Originally Posted by max723
mine slips out of gear to but its a manual. anyone know what could be wrong?
Just trying to help
Yeah don't flush it if it hasn't been done by you before! 85% of the time it'll just cause more trouble than good. I'm not sure why, but I heard that it'll loosen alot of crud and metal slivers that will clog everything up and cause alot of problems
James92SE
142
Jan 2, 2024 09:23 AM
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
