lots of problems lots of money
i went to the shop to get my car aligned and foudn out that to do that i will need new controle arms/bushings/ball joints/hub bearings. and that he will charge me 960 to do it all including alignment..now i can get all the parts my self for around 300. but i also need cv shafts and boots/rotars and breaks/and a tie rod......now my question is, is the car even worth putting all that work and money into it?
also for all you guys with bad idle problems check where your cap and roater were made.....i was told thatif it is from italy that is a huge problem because most the time the elec..jumps so get one from the dealeror make sure it is not from italy.... |
I got a 94 maxima vg30e motor auto 4k on tranny, 275k on the motor im selling for 1200, runs perfect.
Try to do most if not all the work yourself.That will save you a bunch of money and gain you some experience...experience is something that you cannot buy....
eh no tinterested in the motor....mine only has 120k so im good for a while
With only 120k i would definately put the money into the car...It still has a long life ahead of it..... |
dude i would do the work myself its highly doable get yourself a hayes and have fun.
Even cheaper todo is just print the autozone repair pages..They are from the haynes manual..... |
I would be a little sceptical. maybe you should get another opinion from another shop. Rarely would all of that stuff be wrong with your car, rarely would both wheel bearings be bad.
just my $.02 Jeremy |
Try Internetautomar for pricing. Fortunately, most of the stuff you need to change is in the exact same area. Break it all down and reinstall with new stuff.
buy an actual FSM
and the car will serve you for a long time to come. and learning is the best way to save money |
even better....every dollar counts :woot2: |
what is an fsm
factory service manual
if all that stuff is really bad, and you cant work on the car yourself, I would sell the car. $1k is kinda steep for that work. Get another estimate if you dont want to go under the car yourself. |
Absolutely do the work yourself. You'll have to get an alignment when you're done, but it's all within your ability if you can turn a wrench.
There are a few places where you'll need a second set of hands, but all those items are fairly easy to fix. |
if you need help let me know i have a press to do the bearings and bushings and we could proboly do all the work in a few hours
if your going to pay the labor in my opinion its not worth it |
© 2024 MH Sub I, LLC dba Internet Brands
