Sea Foam Question! Help
Old Aug 31, 2005 | 06:32 AM
Maxima Man's Avatar
Hey guys, Yesterday I put 1/3rd of a can of sea foam in the brake booster vacum line. After smoking the whole town I noticed the cars idle would stumble and the slowly recover to about 750 rpms.
The car's engine got hot as crap while running and no air flowing over the radiator to cool it down.
Will this stumbling of engine idle wear off ?
I am going to use another 1/3rd of the can today!
Is that safe?
Old Aug 31, 2005 | 08:33 AM
PunkFriday's Avatar
Power Dorifto Extraordinaire!
i have heard that that the way you did it is right, but i have never done it myself. so i am obviously no help. bump!
Old Aug 31, 2005 | 08:58 AM
Bobo's Avatar
I would be inclined not to add another 1/3 can of SeaFoam and just drive the car for awhile longer and see what happens. Get it out on the highway for a decent run.
Old Aug 31, 2005 | 09:12 AM
bhunter's Avatar
I have heard that people swear by seafoam and have had great results. Your experience sounds sort of like "I drank until I puked last night, should I drink the same amount again tonight and see if it goes better?"
Old Aug 31, 2005 | 09:13 AM
«§»Craig B«§»'s Avatar
did you change the oil afterwards or not read the directions at all?
Old Aug 31, 2005 | 09:41 AM
GREGB287's Avatar
yea dont over do the sea foam ur supose to do it once every oil change tops.
Old Aug 31, 2005 | 09:42 AM
GREGB287's Avatar
yea my idle stumbled as well it wore off after driving for a half an hour and i put 3/4 of the can in.
Old Aug 31, 2005 | 10:16 AM
Maxima Man's Avatar
OK Guys I had already put another 1/3rd of the can in by the time you guys posted (sorry could not wait!)
But the idle did the same stumble routine until it finished smoking then it cleared up I do not see the rpms fluxing and the motor sounds smooth.
I think it could have broken some crap lose and it was messing with my idle, then when I added more SeaFoam it blew it out and started idleing corectly!
I am also going to add 1/4th of the can to the crankcase and whatevers in the rest of the can into the gas tank to clean the fuel system.
I am going to the Auto Parts store to buy some more oil, Do I need to buy a new filter? (I know i was stupid but I changed my oil right before I heard about seaFoam and I have a week old KandN oil filter that cost 10.00!)
Old Aug 31, 2005 | 10:27 AM
Bobo's Avatar
I don't know what to suggest given you have just changed the oil and filter, prior to using the Seafoam. I would hold off putting the Seafoam in the crankcase, however.
You should consider running AutoRX through your engine. See www.auto-rx.com and www.bobistheoilguy.com
It is more effective than Seafoam for cleaning the crankcase and the engine's internals. Seafoam is fine in the intake manifold and throttle body, however.
Old Aug 31, 2005 | 10:34 AM
MAXI's Avatar
Yes, you need to buy a new filter! When you put seafoam there...let the engine idle for about 10 mins. Then change the oil and filter right away.
Old Aug 31, 2005 | 10:36 AM
Jeff92se's Avatar
I'm needing a caw
Incorrect. Seafoam is NOT an engine flush. Actually there is NO recommended interval for changing. But I'd do it maybe 100 miles from the next oil change. 10 min probably wouldn't do anything.
Old Aug 31, 2005 | 10:37 AM
Jeff92se's Avatar
I'm needing a caw
You utes, should really read the Fluids / Lubricants section. Seafoam is talked about in great length.
Old Aug 31, 2005 | 10:44 AM
Maxima Man's Avatar
I have read all the threads on seafoam in the Fluids and Lubricants section and I was under the impression that it would help if I put S/F in my oil then change my oil in a 100 miles it would help clean out the engine.....
Will this work ? Any suggestions ?
I am also going to use Auto RX later when I can order it! (S/F is cheaper and i can get it from my autoparts store easily!)
Old Aug 31, 2005 | 01:12 PM
MAXI's Avatar
oh, okay. i was under the impression that it was almost an engine flush. but this is what i got from one of the threads:
anyway, i highly discourage putting seafoam into the crankcase without changing it immediately after a short run. you will see all the crap it cleaned out, but if you dont change it, it will run it through the motor for the 3,000+ miles...
i dont know how to post a link.
Old Aug 31, 2005 | 03:44 PM
tripleGmax's Avatar
ok so you read everything on seafoam and you still have no idea what youre doing.....
Old Aug 31, 2005 | 04:06 PM
Jeff92se's Avatar
I'm needing a caw
Ask him on what technical basis does he make that claim? Even better ask him how many times he's used it
Old Aug 31, 2005 | 06:36 PM
Maxima Man's Avatar
I knew putting Sea Foam in once would not hurt but I was unsure of twice in the same time frame!
I have read every thread about seaFoam ! But there were no cases of putting it in twice consecutivley!
Thanks guys for the suggestions
Any other suggestions to add?
Old Aug 31, 2005 | 06:52 PM
tripleGmax's Avatar
follow directions next time
Old Sep 1, 2005 | 05:40 AM
Maxima Man's Avatar
The directions did not say not to put seafoam in for to consecutive days !
I read somewhere else that you could add 2 doses in the same time frame !
But i value what you extremly smart orgers have to saw about it !
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
