Injector Removal
Old Sep 15, 2005 | 02:18 PM
hotrod37's Avatar
Injector Removal
I have a 1992 maxima with a vg30e engine. The number one fuel injector went bad. Do I have to remove the entire fuel rail to remove the injector or can i remove the cover over the injector and just pull the one injector out.
Carl.
Old Sep 15, 2005 | 02:40 PM
maximagxe90's Avatar
first of you have to remove the upper intake and lower intake to get to the fuel injector,
second you don't have to remove the fuel rail to remove the fuel injector,
you can just remove that fuel injector and you will be fine,
and another thing don't get remanufactured injector they have a short life cycle,
get new if you can afford it or get used these two will be better for you in the long run,
and if you can afford it replace all six because if one fails the others won't be far a long to fail to,
Old Sep 15, 2005 | 02:45 PM
hotrod37's Avatar
Thanks, I was aware that I had to remove the upper and lower intake and thought i could get away with just removing the one injector. I did buy a new one but I will only be replacing the one since this car is our winter beater because I wont drive my 2005 G35 6mt in bad weather.
Thanks again
Carl
Old Sep 15, 2005 | 07:06 PM
TommyT's Avatar
I just did this 2 months ago. I don't think I could have removed one injector without removing the rail. The rail removal was among the easiest part of the process. The injector removal from the rail wasn't. It took quite a lot of pressure. I had to push it up from the bottom.
Old Sep 15, 2005 | 08:39 PM
MyBlue92Maxima's Avatar
is the number 1 injector top row or bottom row, i dont know how their numbered , but my middle top one went out and i dont remember removing the fuel rails when i changed it
Old Sep 16, 2005 | 06:02 AM
internetautomar's Avatar
mod or sell?
that's because on a VE the front injectors can be changed with no disassembly.
20 minute job, includes pulling car into and out of the bay.
Old Sep 17, 2005 | 05:16 PM
TommyT's Avatar
Makes sense... mines a VG.
Old Sep 18, 2005 | 04:17 PM
kiyakerz's Avatar
where can i get the tool that makes your life a hell of a lot easier when pulling those injectors?
Old Sep 18, 2005 | 04:35 PM
Greeny's Avatar
¯\(°_o)/¯
Sears.......
Autozone.......
Ebay.......
Next door neighbor.......
Old Sep 18, 2005 | 04:40 PM
kiyakerz's Avatar
er sorry guess I should have asked... what is it called? does it have a special name?
Old Sep 18, 2005 | 04:47 PM
Greeny's Avatar
¯\(°_o)/¯
They are sockets with the allen wrenches in the end of them....6mm is the one you need....
my03maxima
Jul 28, 2024 07:40 AM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
