can u mess up a auto trans by over filling the oil?
Old Sep 23, 2005 | 06:20 PM
red-line-racer's Avatar
hey everyone i just wanted to know if its possible to mess up a auto trans by over filling it with atf because the previous owner of my max filled it up passed the full mark on the dipstick and im afraid its gonna mess up my trans should i take some out???
Old Sep 23, 2005 | 06:47 PM
Greeny's Avatar
¯\(°_o)/¯
Just drain some out....The drain plug is on the bottom of tranny facing the front of the car.....You need a 1/2 inch rachet to loosen the plug
Old Sep 23, 2005 | 06:49 PM
wolfpack_5150's Avatar
Apple Pie Monster
answer in short.........Yes and Yes
You can damage by overfilling and as long as you know how to check your tranny fluid and are positive its overfilled you should drain some out. Otherwise it may "burp" out of the breather tube and make a mess at the least. The marks on the dipstick are there for a reason.
Old Sep 23, 2005 | 06:52 PM
tripleGmax's Avatar
might as well just flush the whole thing.
Old Sep 23, 2005 | 06:54 PM
Apple Pie Monster
depending on mileage, and if it was flushed faithfully in the past.
Old Sep 23, 2005 | 06:55 PM
tripleGmax's Avatar
well if guy before him didnt know what he was doing and overfilled it im gonna go out on a limb and say not faithfully flushed.
Old Sep 23, 2005 | 07:02 PM
the oil is a nice light red its not dark i think he just got it done since the car was well mantained
Old Sep 23, 2005 | 07:07 PM
tripleGmax's Avatar
its only supposed to be light red in the 92-94 se's with the VE.........
im just playing , yeah youre probably good by just draining a bit. what i did was i syphoned it out from the fill spot. workd pretty good.
Old Mar 30, 2006 | 06:55 PM
RedDragon's Avatar
Just drain a little and this way you learn how to flush also
Old Mar 30, 2006 | 08:03 PM
aussie983's Avatar
Are you sure you`re measuring it correctly. If measuring it like your oil, you will get an inaccurately high reading. You have to warm it up, drive around for at least 5 mins and move it through all gears, then check it with the engine running.
Old Mar 30, 2006 | 08:56 PM
Dillbag's Avatar
Suprise butsechs!!!
yes, it's bad to overfill the ATF. if too full, the fluid foams, and it looses it's lubricative and fricton properties. (that's bad)
Old Mar 30, 2006 | 09:55 PM
Wolf-Strong's Avatar
I know this may sound bad, but where do you fill it up on a VG?
Old Mar 30, 2006 | 10:08 PM
aussie983's Avatar
er thru the tranny dipstick tube.
Old Mar 31, 2006 | 07:52 AM
maxitech's Avatar
What he said...Just get one of those ling, slender funnels.
spencerwh1
Jun 30, 2016 05:44 AM
foodmanry
Sep 24, 2015 12:02 PM
RWCreative
Sep 21, 2015 11:01 AM
97_GXE
20
Sep 17, 2015 08:12 PM
Maxboy23
Sep 4, 2015 06:04 PM
