Those with short throw shifters
Old Sep 26, 2005 | 08:10 AM
MaXtUneD's Avatar
When I installed my st shifter, Shifting became notchy.....Like you can feel it going into gear..Its not smooth..
I think I read somewhere that the mounting plate that the shifter goes through has a bushing...
What other parts can I replace to get a smoother shifting between gears???
Old Sep 26, 2005 | 08:15 AM
OBEEWON's Avatar
if you tighten the shifter seat too much then shifting will be more difficult. do you have a pacesetter? if you do the ball isnt the best matierial, but if you grease the snot out of it that should help a little.
Old Sep 26, 2005 | 08:18 AM
Greeny's Avatar
¯\(°_o)/¯
Mine was kinda notchy....then i put some high temp grease on all the pivot pionts..That helped......
Old Sep 26, 2005 | 08:37 AM
D-sta's Avatar
I installed a stillen short shifter and no problems whatsoever. Just on the install the first time, I installed it a bit too tight and then loosened it and it's been great eversince.
-Diego
Old Sep 26, 2005 | 08:50 AM
Greeny's Avatar
¯\(°_o)/¯
-Diego
Yea...I also loosened the bottom bolt a little when i greased up the ball and the bottom part.....If you get it too tight it will be hard as he!! to get in gear...
Old Sep 26, 2005 | 09:41 AM
MaXtUneD's Avatar
So Im guessing their aren't any bushings that I can replace to help smooth it out?
Old Sep 26, 2005 | 09:44 AM
Greeny's Avatar
¯\(°_o)/¯
No need to do that unless they are bad.....Just try some of things mentioned above and it should smooth out for ya....
Old Sep 26, 2005 | 09:52 AM
Jeff92se's Avatar
I'm needing a caw
You can't get away from the phyiscs. Nissan crappy tranny + short throw shifter = notchy like a *****. You can run synthetic and keep the adjustment to about 50% shorter but it only helps it and doesn't eliminate the notchiness.
Old Sep 26, 2005 | 11:38 AM
MrGone's Avatar
along with replacing, or filling the actual rubber shifter bushing.
jmlee44
Oct 2, 2022 02:13 PM
Fbana41
Aug 29, 2016 12:18 PM
maxinout93
Oct 31, 2015 02:04 AM
atriuum
Sep 28, 2015 01:19 PM
