weird noise..
weird noise..
I had a metallic creakig noise coming from my front passenger side wheel everytime I braked hard and accelerated hard. I thought it was my shock and mount, so to my surprise after replacing the front shocks and mounts, that noise is back.
I know its not my shocks, mouonts, brakes.. what else could cause this noise? Dont think it could be my tie rods.. what about ball joints, control arm bushings or stabilizer bar bushings... would any of these create a noise when braking hard?
I know its hard to diagnose noises online, but any suggestions of where to look would be helpful.
Probably safe to say the control arm bushings/ball joints are gone on that side....
http://internetautomart.com/ sells the whole arm with new bushings and ball joint....
Originally Posted by adroga
makes sense.. is there a way to check if the control arm bushing needs replacement other than just looking at it?
There is not really anything else that would cause the noise you describe.....10-15 yr. old car..........Definantly needs them....
I've got some clunking coming from the passenger side wheel. Control arm seems fine, ball joint just replaced, it ain't the strut. How do I check the strut mount, and what else could it be?
Good luck
I have it too...new struts,ball joints,tie rod ends, control arms..still makes clunk when you hit a chuck whole.
Originally Posted by Governor
...tire while you watch the control arm bushings. ...
Originally Posted by Will
Clunking can also be caused by worn out stabilizer end links and their bushings.
My sway bar link bushings were broken do to a P/S hose leak...and it had that clucking sound too....
AaronL
Nov 15, 2020 11:52 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
