Intake Question
Old Oct 5, 2005 | 03:43 PM
Brad's Avatar
Intake Question
anyone know who sells 3rd gen cai kits
Old Oct 5, 2005 | 03:46 PM
Brad's Avatar
cant find adapter to connect to the mass air flow sensor
Old Oct 5, 2005 | 03:47 PM
MrGone's Avatar
check out ebay for a MAF adapter
Old Oct 5, 2005 | 03:48 PM
Brad's Avatar
thanks alot
Old Oct 5, 2005 | 04:01 PM
twinkle's Avatar
but get teh 300zx one
Old Oct 5, 2005 | 04:30 PM
Sgibb's Avatar
i got one for the stanza... but it didnt fit right so i had to bolt it with only 2 on a diagonal
Old Oct 5, 2005 | 05:27 PM
AscendantMax's Avatar
got mine from jeff
(the adapter at least)
Old Oct 5, 2005 | 05:37 PM
tripleGmax's Avatar
thats cuz its smaller than ours.
Old Oct 5, 2005 | 05:52 PM
andy044's Avatar
RWD bolt-on conversion?
wait will a full CAI kit for a 300zx fit our car
or at least mine (ve30de)
Old Oct 5, 2005 | 06:09 PM
mattcomet82's Avatar
wow. please check the stickies before shoting q's. you'll find you can answer most of them without needing to ask. the 300zx has a vg block, so it's not a dohc. the 300zx also did not have a transverse mount engine, so the intake is designed and located an entirely different way than a 93 se maxima.
Old Oct 5, 2005 | 06:18 PM
CyMax's Avatar
Old Oct 6, 2005 | 05:34 AM
thajones's Avatar
I had the problem with the adapter thing too, after striking out with all my local shops I was real hesitant to spend money on an ebay one that I'd have a hard time returning.
Also trying to just get that first pipe from the CAI to get rid of the accordian piping seems impossible. I don't see why you can't use a 4th gen one and plug that little hose stub, but again, I hate to waste money.
Old Oct 6, 2005 | 06:49 AM
Wiking's Avatar
Wall Smart sells drill bits...
swiss chees turbo
Old Oct 6, 2005 | 08:37 AM
maximapitko's Avatar
The Bulgarian Guy
wiking, what are the impressions after driLling your air box? Noise,performance?
Old Oct 6, 2005 | 09:40 AM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by Wiking
swiss chees turbo
Old Oct 6, 2005 | 09:49 AM
Kikcaffine's Avatar
I used the whole intake assy. from nopi. The cone and adapter. Worked perfectly, just had to get longer bolts.
Old Oct 6, 2005 | 10:09 AM
kcidmil's Avatar
Just modify the flange inside your airbox. Have that trimmed down, and get shorter bolts.
Old Oct 6, 2005 | 10:15 AM
Wiking's Avatar
The two rivet holes were the worst (as foam strip is between batt) as it allows noise on top, pluggEd. At 3k rpm mama complains but doesnt matter... I suppose noise is lots less than cone filter. Now I have a foam dampener also inside box, to reduce mech amplifier -effect.
The tube before box is worst choke. Then second is the 70mm stock pipe end crimp, see pic. Also TB seals were originally misplaced... plenum 'direct from mold', grinded worst of them off and grinded the mid wall edge. I calculated that intake the area was boosted 20%, 200% at the box. That has a big effect. After mods 0-60 was reduced to near 8s from the stock 9s. Thats not all mods, theres smtg else towards the valves. Now the box is 'semi CAI'; low rpm gets most (?) air from the stock pipe. I would if I could add rubber 'valves' on the holes, opening when air sucks (only full throttle) and could reduce noise, but why? Maybe for cold air sake...
IMpressions: Now 0-60 is definitely below 8s, near somewhere 7.5s... hand clocked time. Time is good enough in our volvo -state (No tracks around). I have been thinking to buy one of those cheap compluter worm boxes for more accurate readings, but dont know whattobuy... has to be cheap.
Another impression: drillin is dirt cheap.
clic http://www.cardomain.com/ride/748507/2
Old Oct 6, 2005 | 10:19 AM
Wiking's Avatar
But its diameter is the same as MAF, no? The most choked point defines total flow...
Old Oct 6, 2005 | 10:32 AM
Jeff92se's Avatar
I'm needing a caw
I congratulated him for making his factory cai into a hai. Hai!
Old Oct 6, 2005 | 10:49 AM
The Bulgarian Guy
that's a crazy improvement though in the acceleration time. I'll be next to try it exactly like that.
Old Oct 6, 2005 | 10:53 AM
Jeff92se's Avatar
I'm needing a caw
Yes, we all know that simple mod can take 0.5 sec off everyone's 0-60 time. That hp increase must be in the order of 30hp in order to do that.
Old Oct 6, 2005 | 10:57 AM
Sgibb's Avatar
where is that flange?
Old Oct 6, 2005 | 11:01 AM
aw89maxSE's Avatar
I picked up the BOMZ intake for the 92 accord and then made an adapter from somwhere like Home Depot and really turned out nice, nice and snug
Old Oct 6, 2005 | 11:07 AM
The Bulgarian Guy
I Don't Think It Works On A Ve
Old Oct 6, 2005 | 11:09 AM
Jeff92se's Avatar
I'm needing a caw
Real cai. Before I painted it.
Old Oct 6, 2005 | 11:12 AM
Wiking's Avatar
Yes Thank you sir. We need all glob_all warmup air here we can get... Maybe this is laziness toward CAI illusion. What my horses want when I whip 'em, is extra gasp on the road, and all they suck is Cold.
Old Oct 6, 2005 | 11:13 AM
The Bulgarian Guy
what kind is that?
Old Oct 6, 2005 | 11:15 AM
Jeff92se's Avatar
I'm needing a caw
but okay
Old Oct 6, 2005 | 11:17 AM
Jeff92se's Avatar
I'm needing a caw
Jeff92se custom fabbed goodness
what kind is that?
Old Oct 6, 2005 | 11:21 AM
The Bulgarian Guy
is there even space for the headlight to go back on? It looks like it's on it's way
Old Oct 6, 2005 | 11:23 AM
Jeff92se's Avatar
I'm needing a caw
WTF? Why would I design something that wouldn't allow for the headlight?
Old Oct 6, 2005 | 11:25 AM
The Bulgarian Guy
take it easy buddy...I wanted to see the pic,that's all...
Old Oct 6, 2005 | 11:33 AM
Jeff92se's Avatar
I'm needing a caw
I'm easy like Sunday morning over here. Let me know when it's done. 90% of the people that want pics, just copy the thing Which is fine
Old Oct 6, 2005 | 12:18 PM
James92SE's Avatar
2 VE's are better than one!
Did everybody stop making CAI kits? WSP?? Place Racing??
Old Oct 6, 2005 | 12:29 PM
Wiking's Avatar
I think its sum of all, few explained on my CD site. Ign is one fraction factor. (Take a calliper rule and walk through all intake, measure and mod/cut ALL choking areas off.) Anyways, stock VG intake is really designed to be restrictive and defined to choke it below the sport segment VE : marketing jippo. What I mean, there seems to be 'more easy sleepin horses' to be trimmed out of VG than VE. (wannabe VE, just watchin experience)
Now after A/T oil change, launch is problematic (to get under 8s.) : time passes by sittin on the ol spinnin cartwheels... Oh boy, this becomes addictive. Anyways, no use buying better tires because soon snow covers all the fun, then my 1.3L Opel -85 is THE king. (want video of the fuming bmw drivers?
Old Oct 6, 2005 | 12:51 PM
ColombianMax's Avatar
Hey Jeff can you fabricate me one too for my VG? I'll pay you,just let me know how much if you decide you can
Old Oct 6, 2005 | 09:47 PM
wsp still makes hai kits for vg motors, 50% sure about cai for a vg though. if you can get ahold of place racing, let everybody else know. you'll be the first in forever.
Old Oct 6, 2005 | 10:21 PM
bmxr152's Avatar
y dont you buy a $20 one off ebay like i did? IT works, fits, and sounds great!
Old Oct 6, 2005 | 10:29 PM
$20 CAI?? or HAI? if you can find me a CAI for 20 bucks for a VG on ebay let me get the link lol.
