89 questions
Old Oct 6, 2005 | 12:45 AM
Shift_my vq's Avatar
89 questions
Well I orgionaly started my maxima life with a 91 3rd gen the I sold it and obtained two 4th gens wich I currently have. And now I obtained a free 89 3rd gen from a really good friend. Well the questions I had were it has messed up windows. The motor works but it's like it's off track. I think I remeber 3rd gens Have bad window regulaotors. Is this my problem? And if so how hard to install? And my othe question is the car has a slight tick. My friend thinks it's because the car's been siting for a year and it needs an oil change. I would have never started it if I knew that but oh well. I love the car just need some help.
Old Oct 6, 2005 | 01:36 AM
Wiking's Avatar
Originally Posted by Shift_my vq
... and it needs an oil change. ...
Open hood & door panel, swap oil, lubricate & get bck on track
Read stickies for FILTER...
Wellcome in to in_dependent suspension club...
Old Oct 6, 2005 | 02:45 AM
VEvolution's Avatar
I miss my VE
Most likely it's the regulators.
Old Oct 6, 2005 | 05:20 AM
internetautomar's Avatar
mod or sell?
change the oil.
change the window regulators <- I sell them
that should solve most problems
Old Oct 6, 2005 | 01:43 PM
cool how much for the driver front and rear? And do 3rd gens handel better than 4ths or what?? I know my 4th doesn't handel that well. And this car handels awesome. I forgot what brand springs it has, and it has tockico blues. I know not the best but I love the way it feels
Old Oct 6, 2005 | 04:36 PM
mod or sell?
the regs are about $40 ea plus shipping.
Old Oct 6, 2005 | 06:24 PM
maxitech's Avatar
ticking could be the exhaust mainifold studs. The factory studs were of inferior quality, so they have a tendency to rust and/or shear.
Old Oct 7, 2005 | 12:38 AM
I'm waiting to see how much money I have coming up but I'll pm you on those regulators when the time comes. I did a lot of work on the car tonight and made some good acomplishments. Changing the oil completly ridded the car of the tick. The old oil was the worth I had ever seen. I put fresh oil in and ran it for a minute and even decided to drain that and refill with fresh oil. And it's like brand new now. Very nice. Got a starter put in. I know easy but now it starts so that's a plus.
Old Oct 7, 2005 | 12:43 AM
actualy my new question is my heater doesn't blow hot air? It's probably the heater core right? My friend said probably not cause it's not leaking in the car??? I thought it was clogged. Any way's if this is the case how hard is it to change it? Anybody got a write up?? Thanks agin
Old Oct 7, 2005 | 01:01 AM
Wiking's Avatar
actualy my new question is my heater ...
More likely the valve: vacuum powered, electronically controlled... Check first the vac hose for brittled ends, if so, cut off [15.] half inch from ends... (For VE hose location differs)
see pages 7 & 8 at http://www.cardomain.com/ride/748507/1
Check Favorite Links at left for writeups
Old Oct 7, 2005 | 06:18 AM
mod or sell?
since you have an 89 the first thing to do is bleed the coolant system.
89 doesn't have the intake bleed valve so you need to jack the nose of the car up so that the radiator cap opening is higher than the heater core (39" up)
it's a fairly common malady.
Old Oct 8, 2005 | 10:51 AM
Maxima Man's Avatar
The 89 se maxima has the bleed screw on top of the intake thing.
Why dosen't it bleed out like 90 -91 maximas ?
I want to bleed coolant too properly I just unscrewed the bleed screw.
I thought that bleed the air bubbles out!
Old Oct 8, 2005 | 11:18 AM
Wiking's Avatar
Originally Posted by Maxima Man
The 89 se maxima has the bleed screw ...
Want Fish? Think like one...
Want Bubbles Out? Think like bubl bubl...
Want know how they roam? Think clic clic at http://www.cardomain.com/ride/748507/1 pages 7 & 8
Old Oct 9, 2005 | 12:24 AM
Ok so I checked all the said above and found it to be ok. My problem is that there is hot coolant in the top hose going into the fire wall even past the valve thing and the bottom hose is completly dry and cool? This means my heater core is cloged right? If not what else? Thanks
Old Oct 9, 2005 | 01:12 AM
Wiking's Avatar
...my heater core is cloged right? ...
Possibly.
Take out the output hose, ask smbdy to start engine. Coolant will splash all around when valve open, coolant circulates ... use extra hose to collect.
IF NOThing comes out, smtg is truly blocked.
Take off the intput hose, install it to output, ask smbdy to start engine. Coolant will splash - IF youre lucky.
If no flow, I'd try to soak dirt off with some chemicals, and/or insert some pressure both directions ...like from tap (careful).
What could be blocked:
- Incoming hose bent
- hose inner lining collapsed, blocking
- worst case cont: buy core (they say some cheap ones fit BUT miss parts of tubing)... rip dash all open, swap.
Whatever - shield u ECU from being fried.
Old Oct 9, 2005 | 06:23 AM
mod or sell?
based on what you've said, I'd try a flush BOTH ways on the heater core and see if that helps.
it did on my buddies old caravan. he went to the car wash and pressured the outlet port, then did the inlet. he got his heat back.
Old Oct 11, 2005 | 06:18 AM
MP3Car's Avatar
that only looked like a few questions, not 89
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
