Headlight problem: Left Low Beam, Right High
Old May 30, 2001 | 07:33 AM
roman's Avatar
I decided to throw the POS "upgrade" harness out and fix my passenger side socket...so just stick with stock setup. I attached a new socket but now the left beam is normal but the passenger side beam is normally high and when I turn on the high beams it's a low beam. Did I cross some wires or something? Does it matter which wire goes into which connector hole? I am guessing it does but I just want to double check.
Old May 30, 2001 | 10:23 AM
«§»Craig B«§»'s Avatar
yeah, you just switched the wires; switch those 2 wires back and you should be fine
the connector has 3 wires, ground (black) , high beam and normal headlights
Old May 30, 2001 | 10:26 AM
DanNY's Avatar
Ad·min·is·tra·tor
if you don't want them you can toss them my way. thanks!
Old May 30, 2001 | 12:11 PM
roman's Avatar
You want the APC upgrade harness? The connectors on the passenger side are kind of burned.
Maxima.KsA
May 15, 2020 04:14 PM
9aj9
Apr 5, 2020 12:11 AM
markevans999
Sep 10, 2015 04:29 PM
mpbclutch33
Sep 8, 2015 06:21 PM
sdotcarter
Sep 2, 2015 09:53 PM
