thumping nosie coming from the wheels???
LOUD thumping noise coming from the wheels???
just bought a 5 speed max off of a member here. just yesterday i was driving and i here a loud thump when i shift to second gear and let go of the clutch fast sounds like something lose but don't see or feel anything???
it something it does it and sometimes dosent i need any ones help it kind of worries me the it might leave me stranded. thanks 4 the help...
if you're letting go of the clutch fast, it could be the throw out bearing. but that wouldnt be coming from the wheels. that would be right in the engine compartment.
its an old car, and if the tranny has never been redone, you might not want to drop the clutch like that? but it shouldnt leave you stranded.
is it only in second?
it could be too much crankshaft end play.
eithert that or your spare tire isnt bolted down tighly
but it also did it once when i was going in reverse
If they are really bad u should be able to tell by looking at them (broken/missing rubber is a bad sign).
Otherwise, have some one in the car and get them to hold the brake in. Put in drive and bring the revs up a bit then try it in reverse (if its a manual release the clutch a bit to load up the motor) and observe whether there is excessive movement at the mounts.
FanaticMadMax
Aug 10, 2015 08:55 PM
BassAddictJ
Aug 4, 2015 11:38 AM
(motor mounts are good)
