wheres the guy who went 12.5 in a 3rd gen
Well I was just wondering if anyone knows or has seen the guy with the tan vg that went 12.5 in the 1/4 lately. He posted some months ago and I havent seen him on the board since.
I haven't seen him since then and I think that was in the early spring, like March or April.
I think he has a 300zx that he runs, or some other turbo racing set up.
My theory is that he was trying to pimp his VG ECU reprogram, but virtually no one in the 3rd gen section has any money, so he had no takers.
well, turbo vg is running 13's, i dont recall what mtcookson ran back when he had a turbo 3g, and brad92se has a trubo ve that runs 13's or 14's i think, these guys, and the guy who ran 12.5 i think are some of the fastest 3rd gens
I know the hakenTT from other forums and... well, lets just say I'm not sure how much I'd believe coming from him. He may or may not have a 12.5 Maxima but not many people like him on the other board and I wouldn't really be surprised if he was lying.
That's just my opinion though.
13.9 is pretty damn quick; im afraid of aftermarket turbos, though.
my friend's is tearing up all of the other components in his car because its so powerful, but its a saab...so go figure.
i know this dude who says his 1.6 liter NON v-tec civic hatchback does the 1/4 mile in 10 secs. i know hes done a lot of **** to it including turbo, BUT THATS PRETTY QUICK.
what does everyone else think about this? line of crap or is it possible?
Jeremy
Originally Posted by Joe Fontinyatz
In the end, which engine has more potential? VE or VG?
Since I (and most of us) can roast my tires with the LSD and no turbo, I just silently closed that IM.
I would guess fully built to fully built, the VE would have a bit more potential, Its 4Valve so its always going to breath better in the top end. In my opinion i think the VG would be easyer and much cheaper to built though, There are more parts available for it. In stock form i think the VG would be able to push more power, Lower compression would come into play eventually
My opinion
Jeremy
My opinion
Jeremy
this isn't the "Viper eater" guy is it?? if so then....ah nevermind.....
The VG shares more in common with the 300ZX motor than does the VE. If the engines were left N/A the VE would probably be better...But if turboed, VG has the upper hand. (No one get their panties in a bunch, that is just a conclusion I have drawn after my time on the org.)
as far as durability between the two, no one can attest to either being that much stronger yet since no one has pushed the limits
Hmm.. funny.
you guys know the VE shares MANY internals with the VG30DE?
namely the same connecting rods. both cranks are forged.
VG-E has tiny wrist pins and the first thing you do when upgrading that motor is to go with VG-DE pistons.
the only thing the VG-E has going for it is aftermarket cams available. otherwise the VE will win hands down. more airflow, forged crank, ALREADY has good rods..
stick some custom ground cams in them (not that $$ compared to building the rest of the engine), and the VE can easily put down 5-600hp if built right.
Originally Posted by Maxpwer
I talked to him on AIM, to ask him which transmission he had and how itwas holding up on those 12.5 passes. When he said he had the VG trans, I told him the VE swap would get him LSD for better traction. His reply was that he has no wheel spin (with his open diff) and no torque steer...........
and we dont need another VE vs VG thread there are too many already but since where on the topic what the hell the VE OWNs the VG turboed as well as NA
Well mod for mod it's hard to say. If you turboed both motors and upgraded the fuel systems the VG would be able to handle much more boost because of the lower Compression Ratio, but then again the VE would spool up alot faster with it's higher Compression. They're really different motors and it would be hard to speculate how they'de compare.
Originally Posted by Akuma2001
the 2jz-gte stock bottom end can handle a 1000hp
the block and crank themselves, sure.
but not the rest of the rotating assembly and fasteners.
needs stronger con rods, beefier bearings with precisely machined mating surfaces, and stronger rod and head bolts/studs throughout.
been there, done that... watched a friend go through 4 engines in less than a year at 'only' 600hp.
Matt 550hp is only a small single for the supra. That engine should easily handle 600hp.
Originally Posted by Matt93SE
No it can't.
No it can't.
Umm...I can find atleast three or four peope who have been running well over 600hp for longer then a year. So..umm..maybe your buddy just can't tune for ****...
No it can't.
Of course you can probably run 1000hp for years if you never actually get it up to 1000hp. Alot of the reliability of the engine is one how HARD you run it. Baby an engine that's CAPABLE of 1,000hp is different than actually running it up to 1,0000hp every day
Originally Posted by Jeff92se
Can you explain the technical differences inbetween the two? Thanks
Maybe a possible reason is, when a block is seasoned then it won't stretch anymore. The cyclinder is already tapered and the head molds to the block better. The area of the cyclinder closest to the head will expand because it is near the combustion chamber vs. the bottom of the cyclinder where the gases have cooled off a little bit.
I thought a perfectly flat deck is best? I'm not sure what cylinder taper has to do with head sealing
the seasoned block is considered better because any shifting of the material should have already occured.
yes blocks do have the material shift when new.
nothing new , newer blocks have less of a problem with it than older ones do
Can't the VE compression just be lowered with a proper head gasket?
Electromotive made a VG30ET produce over 1200 hp in qualifying and run about 900 in the races. They use the stock block and heads and modified accordingly (i.e. they didn't recast the block and heads. they did recast the block out of aluminum down the road but the heads were always stock VG30ET equipment).
Being that the VE is an iron block, aluminum head engine much like the VG30DE(T)(TT) I'd say it would be capable of making quite a bit of power. I wouldn't be surprised if it could make more than the VG. If only they were used longer and in other cars there would probably be many more potential high-power VE's... which makes me think I should have done a VE swap into the Z to see what I could do with it. Maybe that'll be another project down the road.
