pcv valve location (VG30E)
Old Dec 22, 2005 | 01:38 PM
wutsup
can someone tell me where the PCV valve is located in the vg30e engine
(1990 maxima se) thanks
Old Dec 22, 2005 | 02:28 PM
DanNY's Avatar
Ad·min·is·tra·tor
upper right of upper intake manifold. there's a black hose connected to it. the other end is screwed into the manifold itself. it's probably pretty rusty by now.
Old Dec 22, 2005 | 02:33 PM
wutsup
yea thats where i thought it would be but i cant take off the hose. and do i use an open wrench to take it off?
Old Dec 22, 2005 | 02:35 PM
DanNY's Avatar
Ad·min·is·tra·tor
well slide the clamp down a bit..then take your wrench and unscrew it a little...doing that will break the seal with the rubber hose and then you can probably pull the hose off. then finish unscrewing the rest of it out.
open or closed...your call on that one. whatever you do..don't strip it.
Old Dec 22, 2005 | 02:42 PM
wutsup
i think i stripped it a little.......
o and can i take the hose off completely before taking off the pcv valve
Old Dec 22, 2005 | 02:58 PM
wutsup
nevermind i was trying to take of the wrong one. i unscrewed it from the intake manifold but now i just cant get the pcv valve out cause its so rusty.....
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
bumpypickle
Sep 20, 2015 08:22 AM
