Running Rough
Old Dec 31, 2005 | 01:17 PM
jaguax's Avatar
Running Rough
Curses! My reliability streak has just been broken.
I've been driving around yesterday with no probs, but after returning to the car from a store and restarting the car it was running rough. Not that rough as if one of the cylinders wasn't firing, but rough enough that you know that something is definitely wrong. Then I noticed that the check engine light is on. Cool.
I managed to make it home, it was a little smoother at higher RPMs naturally, and when sitting at stop lights I felt like I was in a boat. But it never really tried to stall out so I can't complain.
Anywho, what can this be? The O2 sensor/spark plugs/wires were replaced less than a year and a half ago with a brand new NGK ones so I don't think it's that. Can it be a fuel injector thing? I'm afraid of an expensive repair. Any ideas guys?
Thanks a lot.
Old Dec 31, 2005 | 01:32 PM
red-line-racer's Avatar
could be mostly maf or disconnect each plug to see which one dose not react
Old Dec 31, 2005 | 02:29 PM
Greeny's Avatar
¯\(°_o)/¯
Since your engine light came on it has most likely stored a code...
The ecm is located behind this panel on the passenger side..pull the panel off to access the ecm..
To access the codes Turn the screw using a screwdriver, turn the switch fully clockwise. then look in the little window beside the screw for the flashes..
Old Dec 31, 2005 | 05:06 PM
internetautomar's Avatar
mod or sell?
I'm going to guess injector, because it sounds like what mine did when I had a bad injector or 2 or 3 ....
but you are lucky that it set a code so get the code and START from there
Old Dec 31, 2005 | 05:10 PM
jaguax's Avatar
So you are saying that one of the pistons might not be firing? Wouldn't that make it REALLY rough? I mean it's rough... but not ridiculously rough. I'll probably try it anyway though tomorrow.
Suppose I pull one though and it doesn't react like you said... What does that mean? Bad fuel injector?
I might try that ECM thing too if I don't figure it out.
Thanks for the help so far.
edit - Just read your post internetautomar, how costly of a repair is it to replace the fuel injector?
Old Dec 31, 2005 | 05:13 PM
mod or sell?
depends on who is doing it.
if you do it, it's not terrible becuase it'll be all part cost
if you are paying someone to do it, get out the vaseline
Old Dec 31, 2005 | 07:32 PM
wolfpack_5150's Avatar
Apple Pie Monster
Im with Internetautomar here, I have some missing that can merge into flat out
stumbling on its face. Maybe I'll get lucky and its just the harness. I know if I wiggle the connector near the injector the idle gets better/worse. Check that out urself, ya never know. The fix would be to trace down the break in the wire and splice right? (for the damaged harness).
Friggin injectors vary quite a bit in price, I hope I dont have a bad one and have to cross my fingers and hope I get a quality replacement. Can anyone suggest a good brand, that they have experience with since this route may be the one we have to travel?
TIA
~Brock
Old Dec 31, 2005 | 10:52 PM
mod or sell?
Originally Posted by wolfpack_5150
<snip>
TIA
~Brock
1. only buy new
2. I'd recommend Bosch as they were the original manufacturer and have applied updates to certain part #s
Old Jan 2, 2006 | 09:27 PM
wawa92gxe's Avatar
What about the python ones you carry? I am also looking for injectors.
Thanks.
Denga
Old Jan 3, 2006 | 06:33 AM
mod or sell?
the Pythons are new but they made their own casting for it and I haven't sold any yet to be able to comment ontheir quality
Old Jan 3, 2006 | 10:09 AM
Alex_V
buy new, they lasted 15years and the new ones will probably last the same. Plus if you sell the car, tell them its a bosch and will last another 10 years.
~Alex
Old Jan 4, 2006 | 04:47 PM
cph81's Avatar
If I have to replace a fuel injector, is there any gasket on the intake manifold??
Where can I get it if I need to? How much? Thank you.
Old Jan 4, 2006 | 05:27 PM
mod or sell?
yes there is a gasket
http://internetautomart.com/maxima/3rdgen/FI.html
$10
captchaos
Mar 15, 2016 12:18 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
conansriver
Sep 11, 2015 10:26 AM
ballerchris510
Sep 10, 2015 09:35 PM
