Coolant temp sensor Question!
Old Jan 15, 2006 | 10:33 AM
Maxima Man's Avatar
If your temp gauge on your dash is reading a temp that is mid-way the span of the gauge does that mean your coolant temp sensor is working?
I heard if it is bad it could cause a high idle and I have a high idle I thought I would go buy a new one but I want to see the answer to the above Question First
Thanks Guys
Old Jan 15, 2006 | 02:30 PM
Greeny's Avatar
¯\(°_o)/¯
The coolant temp sensor is a very cheap part,about $20-$25 so it wouldn't hurt to change it out..
It may also be a bad or dirty idle air control valve[iacv]...I would clean it first..Then if that doesn't help it then change the cts...
If you still are having high idle trouble after all that then i have a good used iacv for sale if you have a ve engine...
Old Jan 15, 2006 | 05:22 PM
internetautomar's Avatar
mod or sell?
the gauge recieves it's information froma different sensor
Old Jan 15, 2006 | 05:37 PM
95turbo gxe's Avatar
check your ecu for a code. Does your fans seem to try to stay on after you go to cut the car off.
Old Jan 15, 2006 | 06:35 PM
Maxima Man's Avatar
Whats a cts ? My fans seem to stay on. Even when it is cold out. How many temp sensors are there? Thanks Guys
Old Jan 15, 2006 | 08:57 PM
gawlevi's Avatar
Your temp gauge reads from its own sensor.
Your cooling fans read from the cylinder head temp sensor.
Are both cooling fans on?
Old Jan 16, 2006 | 04:28 AM
Greeny's Avatar
¯\(°_o)/¯
Cts= coolant temperature sensor...
If your fans are on all the time,then i would change the cylinder head temp sensor....
Old Jan 16, 2006 | 05:53 AM
Maxima Man's Avatar
How much do cylinder TS cost? Both fans stay on ! Other cts works I tested it . Thanks Guys
Old Jan 16, 2006 | 07:01 AM
Greeny's Avatar
¯\(°_o)/¯
Old Jan 16, 2006 | 08:44 AM
Maxima Man's Avatar
Are both sensors the one for the gauge and the ecu the same sensor ? I thought they were different ! That one in the pic is the one that is the sensor for the gauge ! That I know for sure ! So are they both the same sensor?
Thanks Guys!!
Old Jan 16, 2006 | 08:57 AM
Greeny's Avatar
¯\(°_o)/¯
Thanks Guys!!
I am pretty sure the cylinder head temp sensor shown above controls the fans and maybe the gauge...You can probably find out for sure by unplugging it after the car is warmed up to see if the gauge stops reading,also if the fans turn off..
Old Jan 16, 2006 | 08:59 AM
mod or sell?
the one above may be for the gauge, but not for the ECU/fans
Old Jan 16, 2006 | 09:11 AM
Greeny's Avatar
¯\(°_o)/¯
Then which one controls the fans?? Coolant temp sensor???
Old Jan 16, 2006 | 09:53 AM
mod or sell?
yup
Old Jan 16, 2006 | 09:56 AM
Greeny's Avatar
¯\(°_o)/¯
yup
Viola!! paydirt!!!
I guess he needs to change the cts then....
Old Jan 16, 2006 | 03:32 PM
Maxima Man's Avatar
So let me get this all straight-
The Coolant temp sensor controls-
-gauge
-fans
The Cylinder temp sensor controls-
What
Are the two sensors mentioned above the same sensor when you go to by the replacment part?
I thought the Cylinder temp sensor had two wires coming out of it !
The coolant temp sensor has ony 1 wire coming out right !
And what is the one above in that pic supposed to be it looks like my cts to me ! is it
Thanks Guys
Old Jan 16, 2006 | 03:59 PM
mod or sell?
Coolant temp sensor:
Controls fans and sends signal to ECU for temperature adjustment
SWITCH-TEMPERATURE W/GAUGE
sends signal to gauge on dash
Old Jan 18, 2006 | 03:00 AM
it would be located on the other side of the pipe (nearest the fire wall) In the water pipe that the temp switch is.
Old Jan 19, 2006 | 11:08 PM
redart's Avatar
And just to add to the confusion, the following pic is lifted from 'pohjola's CarDomain website (hope I'm not infringing copyright!). The sensor on the right is the temp sending unit which gives signal to your temp gauge. The one on the left is the coolant temp sensor which gives it's signal to the ECU for control of fans/idle speed/etc etc. So why is it labelled EGRC ?. Does this sensor handle exhaust gas recirculation also ?.
Old Jan 19, 2006 | 11:12 PM
redart's Avatar
third attempt to post this
MR2 T'd
Jul 9, 2021 05:06 AM
mvm062
Nov 30, 2020 09:00 AM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
