Fuel Injector Removal
Old Feb 1, 2006 | 10:46 PM
92 Max's Avatar
I've just pulled my fuel injector rails on the '92 SE and thought I'd had good luck in finding the correct foot and a half long Phillips head screwdriver to unscrew the injector caps.
However getting the injectors out of the fuel rail is another story. I thought that once you get the metal caps off the injectors should just twist from the rail, however I can twist them, but they ain't coming out. They are very happy where they've been the last fourteen years and seem to be adverse to change. Any ideas on how to encourage them to get on with thier lives and leave the security of the fuel rail (say explosives)?
Old Feb 2, 2006 | 04:21 AM
Greeny's Avatar
¯\(°_o)/¯
If you are replacing the injectors,then get physical with them..
Some pb blaster on them will probably help....
Old Feb 2, 2006 | 04:34 AM
MyBlue92Maxima's Avatar
WD-40 is your friend
Old Feb 2, 2006 | 05:37 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
i'd hope you're in there to change them. put some vice grips on there and just yank the hell out of them.
Old Feb 2, 2006 | 06:16 AM
internetautomar's Avatar
mod or sell?
pull the whole rail and smack them out from the bottom
Old Feb 2, 2006 | 08:01 AM
92 Max's Avatar
Getting Physical with Injectors
Won't this damage the nozzles? I was hoping to inspect them and reuse, if possible. Is there a special tool for removal?
Old Feb 2, 2006 | 08:39 AM
wawa92gxe's Avatar
No damage. Just put some towl in for cousion and give it a gentle tap. They will pop out in one eye blink.
Have fun.
Old Feb 2, 2006 | 08:41 AM
Jeff92se's Avatar
I'm needing a caw
Or just buy my injectors that already have been flowed by RC Engineering and are already in the rail
Old Feb 2, 2006 | 12:27 PM
stephencu2004's Avatar
Hello everyone this is my first post and what a nice site this is I am reading up on fuel injector replacement as I thing I have the same issue as the original poster of this thread.
Thanks for the great info here,
Stephen
Old Feb 2, 2006 | 12:30 PM
Jeff92se's Avatar
I'm needing a caw
There are various ways. I always used a small flathead screwdriver(2 of them). Pry one side of the injector out and spray WD40 down the crevice. Work it around a bit. Then pry it up again. Then use the other and work your way around the injector until it pops out.
Old Feb 3, 2006 | 05:33 PM
maddog12's Avatar
Will all the problems with these injectors, has anybody found any other injectors that would be a suitable replacement. Even if it means splicing harness connectors in? Any other Nissan vehicles have a similar shape / flow rate? I'm just wondering....
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
