*KABLAM* bye VE :(
Old Mar 11, 2006 | 09:23 AM
kiyakerz's Avatar
*KABLAM* bye VE :(
Hm, after all the backfiring my car has been doing and finally getting it down to Nissan.... Turns out this junkyard motor was burning oil like a mad man (and eventually had none left, and i just changed the oil). Which in turn made me a mad man. Nissan Mechanic said my motor is dead, so my dad found me a JDM VE with 30k miles and we'll have it put in monday or tuesday yay!!! Just wondering if anyone has any advice as far as things to save off old motor or to do before new engine is in.
I plan on saving the following
IACV (new)
All Injectors (new)
Coil Packs
Spark Plugs (new)
I bought three New Motor mounts from Internet AutoMart... I think my dad welded my center core support the deal on the bottom, is there anything else that holds the engine in place that may need replacing?
Old Mar 11, 2006 | 12:16 PM
Matt93SE's Avatar
STFU n00b!
check the VTCs and tranny mounts as well. otherwise, change front and rear engine seals and replace tranny output shaft seals while you've got it all apart. will help keep some of those annoying drips down once you get it running again.
Old Mar 11, 2006 | 12:25 PM
Cliff Clavin's Avatar
Way out West
Look in the stickies -- there is a great thread with lots of info by Spipedong and Jeff about what to do for a JDM swap. Jeff did my swap and it has been great so far (knock-on-wood) except I have a slight valve cover gasket leak (no biggie, just got to get another one).
Highly recommended is replacing the manifold studs and water pump while the engine is out of the car.
I don't remember if you have a 5-speed, but if you do, change over the 5-speed intake, so you can retain the VI. Almost all JDM engines are from an AT.
Old Mar 11, 2006 | 07:16 PM
kiyakerz's Avatar
Whats a VI?
Old Mar 11, 2006 | 07:22 PM
internetautomar's Avatar
mod or sell?
Variable Intake
Old Mar 11, 2006 | 09:06 PM
Way out West
Originally Posted by kiyakerz
Whats a VI?
Only the 5-speed cars have it. You never said if your car is a manual or AT.
Old Mar 12, 2006 | 07:24 AM
vansskaterfreek's Avatar
save the 9old motor and try to sell parts off of it maybe??........ keep your coil packs too man.. you might need them along the road
Old Mar 12, 2006 | 12:50 PM
kiyakerz's Avatar
yeah mine is a 5speed... they can't accidently put the new motor in without it can they?
Old Mar 12, 2006 | 01:01 PM
mod or sell?
sure they can, if they don't swap the intake then chances are you'll lose the VI
Old Mar 12, 2006 | 06:54 PM
sell me the VI.......... ha ha.. just pay them a litle extra to swap it....
QUESTION: wil lthe VI work with my automatic VE???? and if so, what do i need???
Old Mar 13, 2006 | 08:16 AM
VEvolution's Avatar
I miss my VE
Are there any visual differences between the VI and the auto one?
Old Mar 13, 2006 | 08:34 AM
dwilson_psd's Avatar
Is there any major differences when you are swapping a VG instead of a VE?
Old Mar 13, 2006 | 09:31 AM
VEvolution's Avatar
I miss my VE
Yeah, different engines.
Old Mar 13, 2006 | 10:16 AM
mod or sell?
Mounts, computer, wiring harness, tranny if it's an automatic.
Old Mar 14, 2006 | 01:31 PM
Sorry guys.
I have done general motors and and Ford motors all my life. So does can anybody tell what tools I need to clean the the FPR screen on a 7.3l powerstroke??? Just kidding. Anyway I have been figureing out all kinds of stuff about my Nissan thanks to you guys.
Daniel
Old Mar 14, 2006 | 02:15 PM
mod or sell?
Sorry guys.
That would be Kiyakerz Department
Old Mar 15, 2006 | 08:18 AM
terryg911's Avatar
It is a big job swapping motors. Good luck keeping the wiring square
Old Mar 15, 2006 | 08:43 AM
I decided to actually stay with the VG30E but i am going to pull it out and rebuild it and then put the same motor back in. Does anybody know about porting heads and mabye doing a little cam work on this car?
daniel
Old Mar 15, 2006 | 03:29 PM
daniel
i was gonna say if you were gonna switch to the VE, switch all the wiring harnesses, because this isnt fun...... http://img.photobucket.com/albums/v2...Picture230.jpg
yeah, i tries wiring up a VE to the VG wiring harness... wasnt a fun week.....
Old Mar 15, 2006 | 04:17 PM
ohhh my word. I think I'lls stick with the VG thanks
that looks like it would SUCK.
Old Mar 15, 2006 | 04:21 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
holy web of wires ! im an electrition and even that scared me a bit ! lol....
Old Mar 15, 2006 | 04:28 PM
what i should have done was gotten a VE wiring harness.....but couldnt find one, so i found a 1992 SE with a blown motor.. then swapped the new VE in.. and it fired right up
Old Mar 15, 2006 | 04:58 PM
mod or sell?
Batman!
and it's spell electrician
Old Mar 15, 2006 | 05:07 PM
HTPerformance's Avatar
Batman!
and it's spell(ed) electrician
^^helped even you out a bit Brian....
Old Mar 16, 2006 | 05:14 AM
mod or sell?
oops :blush:
Old Mar 16, 2006 | 02:33 PM
Hey guys,
I am in the proccess of pulling my VG. Is there any way to quickly disconeect the engine wiring harness? or do do I have to pull all the sensor, injectors etc. I am sure there is an easy way so I thought i would ask. Normally I would just do it the hard way but im learning
thanks
dan
Old Mar 16, 2006 | 02:37 PM
Jeff92se's Avatar
I'm needing a caw
Nope. But it's not that hard. Not a VG but you get the idea: Pic courtesy of mrgone
Hey guys,
thanks
dan
Old Mar 16, 2006 | 02:46 PM
great thanks, I guess i'll pull all the sensors etc (that cannot be unplugged) I also broke the a/c plugin (electrical 1 wire) is there a place to get a new plug??
Old Mar 16, 2006 | 07:16 PM
just re-tape it, or do away with the plug........ on the VG, you should be able to unplug all the sensors and stuff.. you should be able to keep all the sensors attatched to the motor and all the wiring off of it
wyobbagy
Aug 22, 2015 08:14 AM
Ruckus
43
Oct 8, 2001 09:11 PM
Maximamike
Jun 7, 2001 10:26 PM
