how do i fix a leak coming from my winshield washer fluid?
Old Mar 15, 2006 | 09:52 AM
aw89maxSE's Avatar
I had a small leak somewhere leaking where windshield fluid is leaking out. Anystuff I can pour down to clog leak or what should I so. I see the fluid is leaking just in front of front drivers side tire and onto the shield thing and finally rolling of the side of my kit I believe. I am selling my car so I am getting it into tip top shape.
Old Mar 15, 2006 | 09:55 AM
Jeff92se's Avatar
I'm needing a caw
Um buy another fluid resevoir or find which line is leaking and replace that. Even if you bought everthing, it MIGHT cost $20.
Old Mar 15, 2006 | 09:59 AM
aw89maxSE's Avatar
I'm guessing i can find this stuff at a local shmucks or so I need to find one off another maxima?
Old Mar 15, 2006 | 10:02 AM
Jeff92se's Avatar
I'm needing a caw
Or a bone yard. The lines might be an store thing. But really, how hard is it to find the leak? It's only a container, pump and lines. And there's only about 1300 3-gens parting out in the classifieds.
Old Mar 15, 2006 | 10:25 AM
shvelle's Avatar
Correct me if I'm wrong, but isn't the washer fluid resevoir in front of the passenger side front tire?
Are you sure it's washer fluid and not antifreeze? Cause a loose radiator drain or lower rad hose/clamp issues could drop fluid from the drivers side. Could also be that you just got the car really hot and a little antifreeze came out the overflow tube (also on the drivers side).
Take the shields off and inspect.
Michael's Avatar
Back in a 3rd Gen.
I had a leak on my 93 auto. When I poured fluid in it went right to the ground pretty much.
What I found was the hose that connects to it was broken. So take your fender liner out and look under there. It may be simple as the hose has broken or come off.
If its the container itself and cant find them at a junk yard I know i have a couple that are good I can sell for cheap.
Old Mar 15, 2006 | 10:38 AM
aw89maxSE's Avatar
You are very correct. I wasn't thinking when I wrote that (at work ftl). I thought radiator fluid too, but it is just simply water. I will check what you guys said asap.
Old Mar 15, 2006 | 01:26 PM
894DSC's Avatar
Why not use plastic tank repair ??
It costs about 4 bucks from your local hardware store and fixes everything right up !!
Troy.
Old Mar 15, 2006 | 01:35 PM
aw89maxSE's Avatar
how does that work?
Old Mar 15, 2006 | 01:50 PM
894DSC's Avatar
It's a putty you mix up and "Kneed the putty" and it gets hot and very sticky (Wear gloves) and you place the putty over the hole, It glues itself to the plastic surface and pluggs the hole. I have used it on my focus to plug a hole in the coolant tank, Works great !!
Troy.
Old Mar 15, 2006 | 02:09 PM
Greeny's Avatar
¯\(°_o)/¯
http://www.permatex.com/products/aut...Repair_Kit.htm
Old Mar 15, 2006 | 03:14 PM
vansskaterfreek's Avatar
i have a fluid resivoir that i have on my car, that i can get to in about 5 seconds, since i already have the fender loose.... if you ever need one, PM me and ill be glad to send you it....
Old Mar 15, 2006 | 03:33 PM
internetautomar's Avatar
mod or sell?
I guess I'm not the only one with a leaky reservoir.
Old Mar 15, 2006 | 03:49 PM
well if you ned one, i have a NON-leaking resivoir....... it might just be your seals though..... or a broken hose
Old Mar 15, 2006 | 04:51 PM
mod or sell?
or a crack that I can fill with epoxy
Old Mar 17, 2006 | 01:57 AM
rafanthony's Avatar
I have had my max for about a year and have always had this problem never did anything about it. This winter drivring after a snow strom behind a 18 wheeler u find out u need that sh*t
MAXSE5SPD
Aug 23, 2015 12:06 PM
scarletsosa
Aug 17, 2015 09:09 PM
egali045
Aug 16, 2015 01:19 PM
acw
Aug 13, 2015 12:50 AM
