UK Corners
Old Mar 18, 2006 | 06:14 PM
chay2263's Avatar
UK Corners
Does anyone know where I can get UK corners??? And a side question..... I tried to change the fog light bulb and i accidentally rounded off the screws, is there a tool that can still unscrew those bolts??
Old Mar 18, 2006 | 06:18 PM
Josh's Avatar
From someone in the UK or someone on here who has them and is selling them, those are pretty much your only options. As for the fogs craftsman has those bolt removers but i've never used them, also I dont remember how accessible they are but when I have stripped a bolt I find that using a dremel to cut a slot in the top of the head allows a flat head to turn the bolt.
Old Mar 18, 2006 | 07:48 PM
Scriz92SE's Avatar
Try ebay or try google searching for "UKDM Maxima corners" or something to that effect.
Old Mar 18, 2006 | 08:32 PM
Cliff Clavin's Avatar
Way out West
The dremel trick works good.
I had some screws that were recessed and I bought those Craftsman screw out things for $9.99. They worked good, too. I got two of the three out, that gave me enough room to cut the third.
As for the UK corners, you can buy them from the UK (big bucks) or you can pay Michael to paint a set of clear corners for you that look very good and you can still have lights in them. IIRC, the UK ones don't have lights, you have to cut them apart to put a bulb in.
Old Mar 19, 2006 | 07:37 AM
Alex_V
Ive used vice grips when my dremal was too far away. Plus I just moved so its probably packed up in my r/c stuff..
~Alex
NERDJUSTBNME
Sep 30, 2015 03:20 PM
03VQMAX
Sep 25, 2015 04:19 PM
Blkkn8
Sep 22, 2015 06:37 PM
tnewbs
Aug 28, 2015 10:15 AM
wingsfan24
Aug 15, 2015 07:35 PM
