shaving the 3rd gen trunk. Is there a guide? Any tips, what all do i need.
Old Mar 19, 2006 | 12:27 PM
backNblackj30
Im trying to figure out what all i need to get to shave my trunk my neighbor said he can do all of the welding for me if i do all of the sanding, and filling ect.
but he said i need to find out all the parts I will need. and what to use to fill in the gap. who has done this mod, and what was your procedure.
if there is a writeup please post the link, i searched and didnt find anything on it.
thanks guys
Old Mar 19, 2006 | 03:13 PM
mattcomet82's Avatar
shavedmax has all the answers
Old Mar 19, 2006 | 03:23 PM
Josh's Avatar
has this neighbor done serious body work before? I strikes me as all you need is to weld a some sheet metal onto the space and make sure everything is flush.
I would think materials would be sheet metal and bondo but i'm not a body guy. this seems like something i would leave to professionals.
Old Mar 19, 2006 | 04:45 PM
NineOhSE's Avatar
I found this... it seems pretty easy. Just a little welding and such...
http://www.cardomain.com/ride/376954/4
Old Mar 19, 2006 | 04:48 PM
Greeny's Avatar
¯\(°_o)/¯
I think that thing looks like sheit...
Old Mar 19, 2006 | 04:51 PM
NineOhSE's Avatar
I agree... I dont like how they did the 3rd brake light... seems a little outta place.
Old Mar 19, 2006 | 05:02 PM
backNblackj30
that looks awesome! i dont like the brakelight but nice work on the trunk, im wondering what he filld the big gap with, i know sheet metal works, but i was thinknig of maybe filling it with foam that hardens.then welding a peice of sheet metal on top, grinding the welds down, body fillin everything in and sanding, priming, then paint.
Old Mar 19, 2006 | 05:11 PM
internetautomar's Avatar
mod or sell?
he did a nice job of filling and was smart to use the braces to support the metal. Not my taste, but it still came out looking like factory stock except for the 3rd brake light, he did it too low IMO
Old Mar 19, 2006 | 05:16 PM
NineOhSE's Avatar
I dont think he filled it with anything besides the metal braces. If you put the braces close enough together and use thick enough metal to cover them, I dont think you need to fill the gap in anymore.
Old Mar 19, 2006 | 06:37 PM
rteenie22's Avatar
why dont u guys like the middle reflector piece?I think car looks funny without it.
Old Mar 19, 2006 | 06:40 PM
Greeny's Avatar
¯\(°_o)/¯
Huh?? There is only one guy in this thread thats likes it...
Old Mar 19, 2006 | 06:44 PM
rteenie22's Avatar
Old Mar 19, 2006 | 06:46 PM
ozzombie13's Avatar
I will eat your children
anybody feel like doing mine for me? i got an extra trunk.
Old Mar 20, 2006 | 12:47 AM
Loco7's Avatar
well you could do it they way i did... i can't weld worth ****. i took some fiberglass bondo and filled in the top line and sanded don't look bad if you ask me. of course i did it maybe that's why, i wasn't sure how durable it would be but no matter how hard my subs hit it hasn't cracked.
Old Mar 20, 2006 | 07:20 AM
shvelle's Avatar
The timing of this is kind'a funny considering that car JUST went to the wreckers this morning - trunk and all. (I got sick of trying to save the heap)
In my defense, that shaved trunk was only the second mod I'd ever done (the first was shaving the antenna). I was using a flux-core welder with one of those masks you simply hold in front of your face (not advisable).
The trunk previously had a spoiler on it and was very rusty. The 3rd brake light was needed to make it legal (was in the spoiler - and I didn't want to 'just' put it in the rear window like everyone else). Everyone I knew who saw it in person liked it.
How I did it...
Unlike most I've seen done, I took the subtle contour of the tail lights into consideration. I wanted the filler peice to match that contour exactly. So I started by removing the stock center peice and traced it's outer edge onto some metal. I then cut 5 matching peices and used these as my supports (1 on each end and 3 in the middle). I then tried to cover it with 1 peice of metal, but because of the compound bend (up/down & side-to-side), 1 peice wasn't working for me. I ended up using 4 seperate peices to cover it. NOTE: I know now how to cover it with 1 peice.
After that I applied short-strand fiberglass filler and sanded. I didn't have a longboard and was using only a small square vibrating sander - so it took forever... Then I sprayed it with some canned spray paint and clearcoat.
Overall, for my second ever mod I thought it was acceptable. Now, however, I'd expect a better job and have it properly painted when I finished.
What about the 3rd brake light in the trunk was it that people didn't like? (specifically)
Old Mar 20, 2006 | 08:06 AM
Scriz92SE's Avatar
Sorry, I think thats the best looking 3gen tail. IMO..It just looks so..nice..I friggen hate that filler panel. That is definately and makes me wanna ...my only beef with the 3rd gens.
Old Mar 20, 2006 | 08:23 AM
tripleGmax's Avatar
could you please make your signature bigger
Old Mar 20, 2006 | 09:27 AM
Jeff92se's Avatar
I'm needing a caw
Your question
thanks guys
+ this quote
Originally Posted by heresmymind
. my CV shaft boots ripped. i had a fuel injecter problem and my wallet is empty with the possibility of getting kicked out of my house cause my dads an *******. sorry i took it out here. but i had to vent somehow,
Maybe this shouldn't be very high your list of "to do".
Old Mar 20, 2006 | 11:31 AM
Loco7's Avatar
Originally Posted by Jeff92se
Your question
+ this quote
OK I'm confused those are quotes from 2 different people. So why should he wait? Other than if the temp is still cold where he is the filler will never set up right. Unless you have a heated garage. I know that's been the only thing keeping me from doing more body work! Well that and a couple of others.. but that is one of the main reasons
Old Mar 20, 2006 | 12:02 PM
Jeff92se's Avatar
I'm needing a caw
How did I miss that? They post very similar things I think.
Old Mar 20, 2006 | 12:43 PM
NineOhSE's Avatar
I think its the fact that it seems to be floating in the middle of nowhere. IMO, If it would have been a little higher up maybe it would have looked better.
Old Mar 20, 2006 | 01:20 PM
shvelle's Avatar
Higher up on the trunk lid? Or just higher up on the car in general? Cause it was virtually at the top of the trunk lid where it was.
Old Mar 20, 2006 | 03:14 PM
Greeny's Avatar
¯\(°_o)/¯
sake+jeffy posting=ftl..
Old Mar 20, 2006 | 03:48 PM
Scriz92SE's Avatar
Is this better master? Besides, give an Ohioan some luv
Old Mar 20, 2006 | 05:59 PM
MyBlue92Maxima's Avatar
anyone know how much a shop would charge to fill it with sheet metal and finish it , no painting? i would do it but i dont have a welder, nor do i know how to weld even if i did have one >.<
Old Mar 21, 2006 | 09:29 AM
Scriz92SE's Avatar
Take it to Maaco and ask..would hurt I'm sure. Max 100 bucks or so? I dunno
Old Mar 21, 2006 | 10:41 AM
Michael's Avatar
Back in a 3rd Gen.
max $100...I dont think so. To have a shop to it right will probably run around $400-$500 easy. Body work is not cheap.
Old Mar 22, 2006 | 09:38 PM
Scriz92SE's Avatar
I'm going tomorrow to get it quoted, I'll tell you then.
Old Mar 22, 2006 | 09:47 PM
Michael's Avatar
Back in a 3rd Gen.
Well just remember if its $100 dont even bother dropping the car off. I know body work...I do body work and even though I am not a pro I wouldnt do it for under $300.
there is a difference in doing it and doing it right.
Old Mar 22, 2006 | 11:35 PM
Scriz92SE's Avatar
If its anything over 200, I'll just buy a power sander, some epoxy and do the job myself.
I've dipped my hands into a bit of bodywork, nothing in the area of fabrication though lol..We'll see, though.
Old Mar 23, 2006 | 05:53 AM
I'll just buy a welder*
if you take the trunk thing off , the gap is way to big just to be epoxy'ed , it will crack way to easy i believe.
Old Mar 23, 2006 | 05:32 PM
Scriz92SE's Avatar
Like I said, I'll just buy a power sander. I already own a welder.
Old Mar 23, 2006 | 06:44 PM
goon9's Avatar
I would practice on something before scratching up the car. Maybe an extra trunck lid to make sure.
Old Mar 24, 2006 | 10:16 AM
Jeff92se's Avatar
I'm needing a caw
You know how to use it?
Old Mar 24, 2006 | 10:26 AM
Greeny's Avatar
¯\(°_o)/¯
I do .
Old Mar 24, 2006 | 10:28 AM
Jeff92se's Avatar
I'm needing a caw
Speaking of eletrocuting, I shipped your LCRs yesterday fed ex 3-4 days
I do .
Old Mar 24, 2006 | 10:37 AM
Greeny's Avatar
¯\(°_o)/¯
Old Mar 24, 2006 | 11:23 AM
Scriz92SE's Avatar
I'm not the sharpest tool in the shed, but yes I know how to use a power sander. for shop class
Old Mar 24, 2006 | 11:32 AM
Jeff92se's Avatar
I'm needing a caw
How about the welder? Bzzt!
Old Mar 25, 2006 | 08:55 AM
klown_phreak's Avatar
I'm kind of tossed on the reflector on the trunk, some days I think it's "decent" and other days I think it's the ugliest thing I've seen. It wasn't til I seen this car http://www.cardomain.com/ride/835409 that really wanted the reflector off. But of course he has a skyline body kit and skyline tails.
