bolt on so tight...suggestion for substance to loosen it up
Old Mar 23, 2006 | 08:03 PM
aw89maxSE's Avatar
trying to unscrew the two bolts that hold the caliper mount on so I can get my rotor off and those things are on there solid. Any ideas of what I can use to loosen them up
Old Mar 23, 2006 | 08:14 PM
VEvolution's Avatar
I miss my VE
In situations like that, a regular ratchet set wouldn't do the trick. Try something along the lines of a torque wrench, and I'd spray some anti-rust first and let it sink in for a few before trying again.
Old Mar 23, 2006 | 08:16 PM
yay0's Avatar
get some pb blaster and soak em up, then use a breaker bar and you shouldnt have too much of a problem. reg ratchet will never get them off
Old Mar 23, 2006 | 09:31 PM
Josh's Avatar
Just to make sure, your turning it in the right direction right? because I've done that to myself before. and oh yeah everything they said or some wd-40 works well....and i was able to get mine off with a regular ratchet
Old Mar 23, 2006 | 09:59 PM
xnyc's Avatar
soak it, breaker bar, or wrench with a hammer
Old Mar 23, 2006 | 10:02 PM
disgruntled's Avatar
PB blaster, heat, box wrench and a hammer, or just beat near the bolts with a hammer to loosen the rust up, beating on the bolt itself (careful here), or a combination of all of the above plus plenty of cursing should do the trick. Next time you reassemble, dip the bolt in motor oil first, make sure to get some oil or grease into the bolt hole itself, then proceed as normal.
Old Mar 23, 2006 | 10:06 PM
aw89maxSE's Avatar
wd40 failed
old school ratchet failed
going for PB blaster and buying a breaker bar tomorrow
those are the two bolts you have to get off to the get the caliper mount off and inturn get the rotor off so I can get to the wheel studs correct?
Old Mar 23, 2006 | 10:10 PM
box wrench and a hammer for that one then. Make sure you use an extended hex one.
Old Mar 23, 2006 | 10:32 PM
Josh's Avatar
if you use heat be carefull you don't want break the bolt that would be even more fun to get out, no access to air tools i take it?
Old Mar 23, 2006 | 10:35 PM
xnyc's Avatar
if wrench and hammer doesnt work, hammer a lil in the direction to tighten it. keep doing it back and forth and it might break free. and if you plan on using heat, try not to damage the brake lines.
Old Mar 23, 2006 | 10:38 PM
aw89maxSE's Avatar
nope
I think I was turning it the wrong way in the beginning and the tools I have are ancient
I got to finish this tomorrow so I can get to the maxima meet and not miss it for the 3rd time in a row.
Old Mar 24, 2006 | 01:04 AM
yay0's Avatar
Originally Posted by aw89maxSE
wd40 failed
yup those 2 big *** bolts take off the torque member. mine were stuck like yours so i sprayed them with brake cleaner to clean them a little, then soaked them good with pb blaster let em sit for like 5 mins and the breaker bar broke them loose no problem.
Old Mar 24, 2006 | 05:26 AM
DaWifey's90's Avatar
what can my max do for me
i don't know if u'd want to dip them in any oil when reinstalling...i mean u don't want them to come out all that easily considering the minor safety role they play...maybe just a dab of anti-seize
Old Mar 24, 2006 | 06:09 AM
internetautomar's Avatar
mod or sell?
air ratchet FTW!!!
Old Mar 24, 2006 | 06:58 AM
aw89maxSE's Avatar
air ratchet FTW!!!
how about vice grips and a buff a$$ dad FTW?!?!
Finally got them out. Put the new studs in and all that's that left is finding out how a piece of the brake shield isn't letting me get the rotor back on, but I can figure that out after work.
Thanks guys
Old Mar 24, 2006 | 07:26 AM
mod or sell?
hit the brake shield with a hammer , or use the vice grips to bend back the errant piece
Old Mar 24, 2006 | 08:06 AM
Jeff92se's Avatar
I'm needing a caw
You never mentioned what you tried to loosen it with. A little 12" 3/8" ratchet isn't going to produce much torque unless you are Hulk Hogan.
1/4" breaker bar and a 6 point socket. Cheater pipe if necessary.
Old Mar 24, 2006 | 08:18 AM
aw89maxSE's Avatar
Yea that's all I had at all the time but at least we got at it off
Old Mar 24, 2006 | 11:12 AM
Big_E-Dog's Avatar
2nd Gen Boostinator
that always works
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
