brake master cylinder leaking between it and the booster, gasket maybe?
Old Apr 17, 2006 | 04:00 PM
aw89maxSE's Avatar
There is a bad leak coming between the master cylinder and the booster thing (I think it's called). Is there a gasket needed to be changed or the whole master cylinder?
Old Apr 17, 2006 | 04:12 PM
Greeny's Avatar
¯\(°_o)/¯
Whole new master cylinder time...
Old Apr 17, 2006 | 04:23 PM
aw89maxSE's Avatar
FTL
Old Apr 17, 2006 | 04:26 PM
Greeny's Avatar
¯\(°_o)/¯
I think i have a used one laying around somewhere if you want it..
Edit: wont work,mine is different..
Old Apr 17, 2006 | 05:33 PM
«§»Craig B«§»'s Avatar
yeah, the brake booster is all vacuum and has no fluid in it so definitely no gasket there
Like greenmax said, you're probably looking at a new master cylinder. I had the exact same thing happen on my prelude
Old Apr 17, 2006 | 06:55 PM
internetautomar's Avatar
mod or sell?
just remember there are only 2 masters, with and without ABS
I
Old Apr 17, 2006 | 11:27 PM
aw89maxSE's Avatar
I don't have to abs and I looked at the chiltons and it didn't look like it was too hard to change. Any additional info on it before I do it?
Also, why is it leaking since there is no worn gasket there?
Old Apr 18, 2006 | 06:26 AM
Matt93SE's Avatar
STFU n00b!
there are several rubber o-ring seals inside the master cylinder itself. those are what's leaking and they always leak out the back (open) end of the MC. the fluid will run down the brake booster in between them.
fix it quick and be sure to clean out all the gunk on the brake booster, otherwise it will eat through the rubber on the booster and you'll wind up changing it as well. and that is NOT FUN. trust me there.
As for changing the MC, it's not hard.. couple bolts holding it to the booster and the 4 lines. with some of them you have to swap over the reservoir.. just pry the old one out with a screwdriver and clean it really well so it's nice and pretty. let it dry in the sun for a while to remove all moisture, then lube the fittings with clean brake fluid and press back into the master cylinder.
then be sure to bench-bleed it as per the instructions. If not, you'll have spongy brakes for decades!!
then connect the lines back up and bleed the entire system again and you're good.
Old Apr 18, 2006 | 07:39 AM
MAXI's Avatar
idiot question here.....
what is bench bleed? and how to do?
Old Apr 18, 2006 | 08:24 AM
DanNY's Avatar
Ad·min·is·tra·tor
you bleed the MC on the bench. fill it w/ fluid and push the plunger in a few times. that will work the air out and get some of the fluid going.
Old Apr 18, 2006 | 10:08 AM
93MaxMurf's Avatar
i also have a brake fluid leak, what should i check to see if it is the break lines or the master cylinder that is leaking?
Old Apr 18, 2006 | 10:12 AM
Jeff92se's Avatar
I'm needing a caw
I have a VE 5-sp brake booster for sale if anyone needs one. It will "probably" work for auto and VG versions.
Old Apr 18, 2006 | 11:19 AM
DanNY's Avatar
Ad·min·is·tra·tor
where is it leaking? open the hood and you should find your answer. if it's been leaking for a while find the paint that bubbled up too.
Old Apr 18, 2006 | 12:16 PM
mod or sell?
ABS or Non?
Old Apr 18, 2006 | 12:21 PM
Jeff92se's Avatar
I'm needing a caw
It came off an ABS equipped 5-sp
Old Apr 18, 2006 | 01:01 PM
mod or sell?
ah, the bigger booster.
Old Apr 18, 2006 | 03:17 PM
aw89maxSE's Avatar
I guess I need another MC, anyone got one?
Old Apr 18, 2006 | 05:34 PM
Greeny's Avatar
¯\(°_o)/¯
Old Apr 18, 2006 | 05:53 PM
Greeny's Avatar
¯\(°_o)/¯
Old Apr 18, 2006 | 06:45 PM
aw89maxSE's Avatar
how much?
Old Apr 18, 2006 | 06:49 PM
Greeny's Avatar
¯\(°_o)/¯
how much?
YGPM.......
Old Apr 18, 2006 | 06:56 PM
Greeny's Avatar
¯\(°_o)/¯
Old Apr 20, 2006 | 10:11 AM
Jeff92se's Avatar
I'm needing a caw
Originally Posted by MyGreenMax94
Old Apr 20, 2006 | 10:51 AM
Matt93SE's Avatar
STFU n00b!
that's why I said above "as per the instructions"....
1. Buy new MC.
2. open box.
3. read instructions inside box.
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
The Wizard
24
Oct 1, 2015 08:47 PM
bbsitum
Sep 11, 2015 04:55 PM
