vin check?thanks either way
Old May 10, 2006 | 12:02 PM
Yourself
jn1ejo1f8nt117095
this is a car i bought w/ a "dead" motor (92'se auto.gold practically free)turns out the left intake cam v.t.c.
end cap broke,fell down by left lower chain sprockett,busted out the chain cover,broke a small chunk of the left lower sprocket bolt hole,which moved chain causing 3 exhaust valves to break and one roller rocker to snap
i got lucky with a $100 spare motor that he said had bad rings
and swapped heads ,chains ,tensioners ,guides,injectors,lower intake,etc.
and now have a spare with one bad head and bad rings
so far running good got it thru emissions and transfered over to me
Old May 10, 2006 | 02:43 PM
nos487's Avatar
I ran your vin on nissan and it has (R5002 95V-244 J30/U12 CORROSION)recall. Need to take to dealer and have them take a look.
Old May 11, 2006 | 11:31 AM
Yourself
before i took it i looked behind the trunk walls around the seat belt mounts
and in the whell wells and under it looked all good
and since im keeping it i already cleaned behind the fuel neck cover
could there be other areas? did anything else come up? thanks
Old May 11, 2006 | 06:02 PM
nos487's Avatar
Thats all the recalls it has and you looked in all areas of concern. They will replace the fuel filler neck if I remember right. I have a copy of the recall at work I will look it over tomorrow.
salty318
Sep 28, 2015 07:22 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
rbaker100
Sep 25, 2015 07:52 PM
