caliper probllem
Old May 14, 2006 | 05:46 PM
SurraTT's Avatar
HR Swap Pioneer
caliper probllem
ive read up and im thinking the caliper seals or something are going
the front left caliper makes this squeeing crunchin noise when the brakes are pressed, it is loudest when not even rolling
i took the caliper off and put the brake lube on the pins and stuff. it sill does it
i think its something wrong with the pistions, sometime when im driving i notice the right wheel seems to brake harder and it pulls that way
when i took it off i noticed the brake pad wasent all being used like 2mm wasent touching the rotor so it was taller and not evening worn down, it seems the rotor is too big and dosent use 100% fo the pad
there is a 300zx caliper at advance for $70
idk if i could do a rebuild on my own
btw ive got 300zx 4 piston calipers
but i also have the stock calipers i might try them, i would need some stock rotors
Old May 14, 2006 | 06:04 PM
internetautomar's Avatar
mod or sell?
whose BBK is on there?
or is it just the 300Z calipers?
Old May 14, 2006 | 06:17 PM
SurraTT's Avatar
HR Swap Pioneer
umm idk
its 300zx calipers
13in mustang rotors
thats all i know about it
Old May 14, 2006 | 06:35 PM
SurraTT's Avatar
HR Swap Pioneer
i also noticed everytime it rains the rotos get rusted VERY quicky
they seem to rust within 30 min its crazy
anyone else notice this??
my other max rotors only rusted if set for like 1 week no where near a 30 min after rain
Old May 14, 2006 | 07:37 PM
mod or sell?
i've seen the rust issue before.
but for the rest of the problem IDK
Old May 14, 2006 | 07:52 PM
mattcomet82's Avatar
i've noticed my front calipers make a horible screeching noise once they warm up, but then quiet down when i brake. i'm looking at replacing both units, i can get a reman set @ schucks for 55 per side with core, lifetime warranty. i ususally hate going to schucks b/c they are idiots, but a liftime warranty is what i need.
Old May 15, 2006 | 04:11 PM
SurraTT's Avatar
HR Swap Pioneer
well today i noticed some lines lookes like something is on the pad or its messed up in some way
pic http://www.surrattracing.com/IMG_0696.JPG
i think im going to switch the passenger rotor over to drivers side, would that cause more problems????
Old May 16, 2006 | 08:24 AM
92 Max's Avatar
Is this correct? The noise happens when the wheels are STOPPED?
Old May 16, 2006 | 11:57 AM
SurraTT's Avatar
HR Swap Pioneer
yes
and when stopping quickly from rolling
Old May 16, 2006 | 12:30 PM
92 Max's Avatar
Grunch
Do you have ABS brakes?
Old May 16, 2006 | 01:16 PM
UMD_MaxSE's Avatar
Got Bent?
I have this crunching noise as well on my 300ZX calipers w 2k4 rotors on my 5th gen... just ran across this thread by accident
I've inspected the pads and the rotors without taking anything apart and everything seems to be wearing just fine. I suspect that the back of the pads and the shims are not greased up enough. When you apply the brakes, the caliper pistons push on the back of the shims and if there isn't enough lubrication, they creak and make all kinds of noise. My pads have about 30k miles on them now and are half way worn. I have slotted rotors, and want to change them out for blanks so I may just go ahead and switch everything out sooner...
By the way, I see nothing wrong in that pic that was posted. That looks like normal wear on the rotor...
Old May 16, 2006 | 05:14 PM
SurraTT's Avatar
HR Swap Pioneer
abs yes
i dont think tis the pad greese i actually re greesed everythign and it sill does it
the pic
there and some areas where the rotor has weird spots, is it just me??
i think the caliper seals and going out and its weak
Old May 16, 2006 | 08:31 PM
UMD_MaxSE's Avatar
Got Bent?
Did you make sure to grease the back side of the pads plus the shims by removing the pads from the calipers? The pins are not enough... plus, do you have all the metal pad retainers in there? The ones that go on the corners of the pad might by sticking or could be missing...
Old May 20, 2006 | 06:28 PM
SurraTT's Avatar
HR Swap Pioneer
i ordered some pad shims today
im allmost 100% sure thats the prob, as there are no shims on drivers side, idk about passengers side, idk why they are missing
Old May 21, 2006 | 04:40 PM
Mizeree_X's Avatar
Getting back to his roots
The shims are the adhesive type, they should be stuck to the back of the pad.
Old May 22, 2006 | 08:20 AM
vansskaterfreek's Avatar
maybe it is not the caliper..... it might be another problem...
Old May 22, 2006 | 08:29 AM
Jeff92se's Avatar
I'm needing a caw
I have a spare set of front calipers/rotors from my bbk conversion. They worked perfect when removed. Local sale would be best for how heavy they are.
Old May 22, 2006 | 12:11 PM
SurraTT's Avatar
HR Swap Pioneer
oh, well i guess they might just be worn out?? they def had a ring in them
Old May 22, 2006 | 09:37 PM
would these clear my stock rims tho?
edit: silly rabbit, you mean oem units
Old May 23, 2006 | 09:02 AM
Jeff92se's Avatar
I'm needing a caw
yes Have you replaced yours yet? If not, this would be the cheapest way by far. I also have the rotors and brake lines(although the lines are probably as old as yours) But all were working fine when pulled.
Old May 23, 2006 | 06:25 PM
yeah, i went ahead and got 2 loaded reman. calipers from napa for 140 with lifetime warranty. even came with semi-metallic pads. i may still need a set tho for my dad's rig. i'll pm you , i've whored out this thread enough.
Apr 16, 2020 05:15 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
Bonka
Sep 14, 2015 11:18 PM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
