Please Help
Old Jun 17, 2001 | 06:46 PM
ljmayfield's Avatar
I just bought my second maxima. It is a 91 SE. When I bought it... they told me that the rack and pinion was bad. So I had that replaced. It cost me $400 but did not fix it. I was wondering if any of you have had this problem and could tell me what it was.
When I'm going down the road and step on the gas the steering wheel jerks to the right and when I let off it jerks back. I only happens when it is under a load.
If any of you guys could help it would be highly appreciated. Thanks again.
Justin
Old Jun 17, 2001 | 07:18 PM
Chris Gregg's Avatar
Get Off My Lawn
tourque steer?
Old Jun 18, 2001 | 03:24 AM
ljmayfield's Avatar
I'm not sure.
Old Jun 18, 2001 | 04:33 AM
Maximum5spd's Avatar
Justin
Hmmm, it seems to me alot of maximas have this problem, I had it as well. My friend with a 92 Se had it. I had to change the whole suspension to stop that jerk. But I think what stopped it was the struts and strut bar. I suggest you should try that.
Old Jun 18, 2001 | 05:23 AM
C-Dawg's Avatar
Justin
Sounds like an odd problem. I am not really sure what it might be. If others have had this problem such as Maximum5spd, then maybe you should take their advice. They may be able to give you the cheap and easy solution. (If there is one )
Old Jun 18, 2001 | 01:53 PM
ljmayfield's Avatar
I hope so. The rack was a very exspensive trial and error. Especially scince it was an error. I'll try the struts this weekend and if you guys have any more suggestions or experinceces... send them my way.
Thanks,
Justin
Old Jun 18, 2001 | 02:10 PM
Matt93SE's Avatar
STFU n00b!
Check all your ball joints and suspension parts before you replace the struts. the struts are $130 each, so it's still not a "cheap" fix- even if that is the problem.. but whatever it is, you need to fix it whether it's $10 or $100.
but my first thoughts would be ball joints or suspension bushings. jack the car up and see if there's any "play" in the wheel when you grab the top and bottom and try to rock is back and forth.
good luck.
