How much drop?
Old Jun 9, 2006 | 09:19 AM
Black92GXE's Avatar
Boomer Sooner
How much drop?
Hey all! I was looking to replace the struts on my max and was thinking of replacing the stock springs to drop the car while I'm at it.
My ? is -- Is a 2" drop too much to have some 17's (likely stock infinity rims or max rims) and the appropriate tire to yield the same overall size as the stock 15" wheel & tire combo, or should I stick with a 1"-1.2" drop?
Also, are sprint springs any good as these are the ones I am looking at and they provide the drop in question above.
Thanks all for your help! I have read the stickies and searched and can't seem to figure out if it rubs or not as everyone seems to have a different answer - just hoping to get a more consistant answer here.
Old Jun 9, 2006 | 09:57 AM
CamryKilla's Avatar
for a big drop spring, i'd say go intrax. great quality and looks. and i dont think the amount of drop is as big of a deal when it comes to fitment as the wheel's offset and tire size
Old Jun 9, 2006 | 02:23 PM
Sean@Home's Avatar
It really is personal prefererance. I Just did struts/springs and debated for a while if it was gonna be intax or eibach. 2" or 1.4" and opted for the eibach because i prefered the look. as the person above me said it has alot to do with the offset rather then the size of the rim. I got 18x8 g35 rims with +30 offset and ive ran both 235 & 225 40 18's with no rubbing issues. That being said i would also work within your budget, Dont opt for ****ty springs & struts so you can get bigger rims.
Old Jun 9, 2006 | 03:39 PM
MrRose350Z's Avatar
INTRAX / TOKICO, with 17"... ROTA 17X7.5" with Khumo 235/45/17s H&R spacers with extended studs... No rubbing on the fenders, fenders NOT rolled.
Old Jun 9, 2006 | 05:43 PM
Cliff Clavin's Avatar
Way out West
The amount of drop is really determined by you. How low do you want to go?
Aside from Shavedmax (bags) I think the general consensus on this board is go with Sprint for maximum drop (2 inches), Intrax for a lower drop (around 1.75 inches) or "standard" Eibach drop of about 1.2 inches.
KYB or Tokicos are a minimum for struts. They still might blow out on you. A lot of guys have had to replace blown Tokicos. I think Jeff and Matt can attest to this. The optimum struts are Konis, but they are more expensive and require a little bit of extra work on the rears. No matter what, OEM replacements (Gabriel, Monroe, etc) are not recommended.
Old Jun 9, 2006 | 06:46 PM
MrRose350Z's Avatar
[QUOTE=Cliff Clavin]The amount of drop is really determined by you. How low do you want to go?
Aside from Shavedmax (bags) I think the general consensus on this board is go with Sprint for maximum drop (2 inches), Intrax for a lower drop (around 1.75 inches) or "standard" Eibach drop of about 1.2 inches.QUOTE]
Thanks for reminding me that SPRINT was a 2" drop. Good info. Next time... SPRINT and a 225/45/17s.
Old Jun 9, 2006 | 07:59 PM
Black92GXE's Avatar
Boomer Sooner
Ah, ok - Awesome. So Sprint are good, just the lowest drop.
I was thinking before this post of Eibach and KYB's. maybe even Intrax - but don't want to go completely down.
By the way - how do you blow a strut unless you just abuse it?
edit: Oh, and if I had the money I'd say screw the struts and springs and just buy your car Cliff!!!
Old Jun 9, 2006 | 08:06 PM
todamax's Avatar
Here is my car on Eibach/Koni with 16" 2K SE wheels.
Old Jun 10, 2006 | 04:46 AM
sublunary's Avatar
i went with eibach/kyb (too many other things to do on car to afford konis) and i am glad i didn't go lower. it is about personal preference but it is also about road conditions in your area. i live in boston and potholes are everywhere and patched potholes are sometimes worse. i see guys with slammed cars all the time who can't drive the speed limit because they have to be so carefull
Old Jun 10, 2006 | 12:39 PM
MrGone's Avatar
Eibach/Tokico (or Koni) imho. Handles great and isn't low enough to be a headache.
Old Jun 10, 2006 | 01:24 PM
pitchedup's Avatar
I have a eibach and tokico combo. Its only a 1.2 inch drop, but gives you some suspension travel so you dont have to hit bump stops all the time.
I drive to and from school/work and one of my struts blew in less than a couple weeks after it was put in. Lucky I got a free replacement from tokico.
Old Jun 10, 2006 | 07:34 PM
internetautomar's Avatar
mod or sell?
it's the front that requires the extra work
Old Jun 10, 2006 | 11:01 PM
maxitech's Avatar
I thought long and hard about what I wanted to fit my car with. Konis are the only struts with great feedback. If you are going to spend the money on a new setup, spend the extra and ge Konis. As for the drop, I went Eibach because of the sh!tty roads around here and ground clearance issues. Anything lower than Eibach's 1.2 inch drop deserves a Blehmco camber kit. Do your homework and make a decision. We're here to help...Best of luck!
Old Jun 10, 2006 | 11:22 PM
todamax's Avatar
Actually the rears have always been more trouble. Though I guess that goes for the GXE's more than the SE's. Disconnecting the brake setups can be real easy ot take a looooog time. I even had a gland nut that I had to cut out once, no amoutn of heat, pb blaster ot torque would get it free. Turned into a day for one corner...
Old Jun 11, 2006 | 02:16 AM
MrGone's Avatar
yeah, but installing Koni's on the front actually takes extra steps (more work)
Old Jun 11, 2006 | 08:44 AM
ozzombie13's Avatar
I will eat your children
we got some nasty pot holes around south jersey too. but i guess thats almost anywhere with a big city close by
but i am very happy with the ebiach/kyb set up. handles great and its not too low.
Old Jun 11, 2006 | 10:04 AM
fernyhcc's Avatar
just drop it all the way to the floor. slam it
Old Jun 11, 2006 | 10:44 AM
pingpong's Avatar
GXE back from the dead
tokico blues/sprint springs is what i have with 18x7.5 wheel and 225 40 18 tire also put on 8mm spacers all around
no rubbing
Old Jun 11, 2006 | 10:46 AM
pingpong's Avatar
Old Jun 11, 2006 | 11:14 AM
Maximahappy22's Avatar
I bought eibachs from nopi and konis from brian i think from internetautomart.com but i havent installed them. ive heard too many bad things about tikocos and kybs.
Alex
Old Jun 11, 2006 | 02:11 PM
mod or sell?
Alex
nopi was cheaper than me on the eibachs?????
Old Jun 13, 2006 | 11:00 AM
MrRose350Z's Avatar
I had Eibach / TOKICO for 2 years. The ride was harsh, and it still looked like a 4X4. Switched to INTRAX and new TOKICOs. The ride even out and no more 4X4 look.
The original TOKICOs / EIBACH combo... struts were still good.
It's a matter of spring rates, not "lowering preference". Spring rates are the key.
Old Jun 13, 2006 | 11:44 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
eibach
intrax
Old Jun 14, 2006 | 05:46 AM
MrRose350Z's Avatar
TOO CLEAN, TOOOOOOO CLEANNNN!!!
I think Sprint is a linear spring, and the INTRAX are progressive.
[/QUOTE]
Old Jun 14, 2006 | 05:49 AM
MrRose350Z's Avatar
At this hour of the day I am thinking...
Put the Sprint Springs in the FRONT and the INTRAX in the back.
That way the car would look level.
Old Jun 14, 2006 | 06:53 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
thank you sir welcome back... i see you've been active on a few boards
yo are correct about sprint/intrax
Old Jun 14, 2006 | 07:27 AM
MrRose350Z's Avatar
Your Car is in a world of it's own Chris.
I think you might need to be the guinea pig for mixing springs. Front Sprint / Rear Intrax.
What do yah say?
Old Jun 14, 2006 | 07:41 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
What do yah say?
In due time maybe. long story short the car has been sitting for almost 2 years. i finally have a garage to work in so once i bring her back to life i may do it. always thought about that combo but i got lucky. on intrax it sat even all the way around even w/ all the crap in the trunk.
Mar 12, 2020 12:06 AM
jonreidhead
Jan 6, 2016 09:38 AM
Turbonut
46
Oct 21, 2015 08:28 PM
maxima-junky
Oct 7, 2015 06:13 PM
Redfox
Sep 28, 2015 10:41 AM
