glue around transmission fill plug
Old Jun 11, 2006 | 01:13 PM
wutsup
hey guys i just found out theres some kind of glue aroudn the transmission fill plug? i dunno i took a razor and scraped off as much as i could. is there suppose to be glue around it? sorry for another post
Old Jun 11, 2006 | 01:37 PM
Greeny's Avatar
¯\(°_o)/¯
Mine didn't have any glue on it...
Old Jun 11, 2006 | 01:59 PM
ozzombie13's Avatar
I will eat your children
dosent sound like it should have any thing does it leak now that the glue is gone? you might need a new drain plug
Old Jun 11, 2006 | 02:13 PM
wutsup
no leakage, i guess theres still glue inside so its impossible to get off. eh ill just have to deal with the little notchier shifts. and i wasted about 20 bucks on the wrong kind of gear oil anyways (GL-5).
Old Jun 11, 2006 | 02:52 PM
Matt93SE's Avatar
STFU n00b!
use a short extension and a breaker bar to pop it loose.
a lot of times you will get seepage around the fill plug if you don't put a small bit of RTV on it. usually all I do is put a thin layer of RTV on the threads when I put it back in and I don't have any problems.
Also note you don't need to crank that thing in there like that. (I've even seen tranny cases crack because of people putting them in too tight.) all you need to do is get it snug and use the RTV to keep the thing from seeping.
Old Jun 11, 2006 | 03:18 PM
wutsup
so u mean just try to pop it out without turning it?
Old Jun 11, 2006 | 03:39 PM
Alex_V
No he means unscrew it like normal, you just need to use an extension and a breaker bar to loosen the plug.
The reason you are having so much trouble is the person to last put the plug in used too much RTV on it and over tourqe'd it
~Alex
Old Jun 11, 2006 | 03:58 PM
wutsup
i tried i cant break it loose, so i dunno...u mean like try to hit it loose before unscrewing it?
Old Jun 11, 2006 | 05:13 PM
MikAus's Avatar
HYELLL NO, don't HIT it with anything, you'll most likely miss and smack yourself in the head with it.
go to the hardware store and buy yourself an iron pipe approx 12 inches long
eg gas line pipe 1 inch
slide this over your ratchet handle, this will give you plenty of leverage.
good luck and be safe ...
Old Jun 11, 2006 | 07:54 PM
Matt93SE's Avatar
STFU n00b!
breaker bar = long handle wrench that gives you tons of leverage.
think about it... what good is banging on it going to do?
Old Jun 11, 2006 | 08:52 PM
maxitech's Avatar
Leverage is your friend!
mvm062
Nov 30, 2020 09:00 AM
Mar 12, 2020 12:06 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
