Replace Springs with Struts or no?
Old Jul 8, 2006 | 11:28 AM
tverner's Avatar
Just ordered a pair of KYB struts for $190 a pair shipped from a seller on Ebay (brand new). I found a pretty good deal on Eibach pro springs as well. Wondering if I need to change my springs while I am in there. I don't need the thing to handle like a beemer but need to know if the accordian motion I am getting on the freeway when goving over depressions is caused by worn springs or worn struts??? Thank you.
Old Jul 8, 2006 | 11:48 AM
Cliff Clavin's Avatar
Way out West
Your problem is worn struts, not likely the springs. Once you put the KYBs on, the "accordian motion" should subside quite a bit.
If you want a more aggressive stance (about 1.2" lower) and better handling, I would get the Eibachs, too.
I would recommend the Eibachs if you can afford them. They are a little bit stiffer, but still comfortable and it improves cornering immensely.
Old Jul 8, 2006 | 01:39 PM
u dun 4's Avatar
Wow I will have to look into some good struts because mine have not been changed to my knowledge in 190,000 miles. I prolly have to change mine cause i get a "accordian motion" when I turn. But I wonder should I change all 4 or just 2 and then where could a get a good priced one. Im no baller so I don't do the 400.00 dollar shocks type mod. I just want a good pair so my ride can be more comfortable.
Old Jul 9, 2006 | 12:15 PM
tverner's Avatar
Thanks for the help Cliff, that makes sense. Think I will pass on the springs, it is my wifes car and it has 205,000 miles on it (89 Maxima). Anything else I should consider replacing while I am in there? Thanks.
Old Jul 9, 2006 | 02:57 PM
Greeny's Avatar
¯\(°_o)/¯
Everything....
Old Jul 9, 2006 | 05:54 PM
ozzombie13's Avatar
I will eat your children
upper strut mounts and all the bust doots and bump stops dependinng on the condition
Matt93SE
May 24, 2019 02:58 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
schmellyfart
Sep 25, 2015 04:47 PM
95Maxi
35
Sep 2, 2015 10:37 AM
laparka66
Aug 6, 2015 09:36 AM
